  2. Celsius Thermal Solver
  3. How to build a graphite sheet model in EC (6sigmaET)
  • Subscribers 15
  • Views 2541
HC202506028620
HC202506028620 over 1 year ago
We use lots of graphite sheets in mobile devices to spread hot spot, as known as the material is thin (0.1mm), and the orthogonal thermal conductivity at different axis.
how to setup the model and grid control to perform the spreading effect and least grid numbers?
  • NS1170
    NS1170 over 1 year ago +1
    You can assign the required thickness to the solid obstructions and provide the grid constraint around the graphite sheets. Ensure that the grid size is smaller than the thickness of the sheets, to ensure…
  • HC202506028620
    HC202506028620 over 1 year ago +1
    Which grid number is suggested? the thickness is 0.1mm, the aspect ratio can be huge
  • NS1170
    0 NS1170 over 1 year ago
    You can assign the required thickness to the solid obstructions and provide the grid constraint around the graphite sheets. Ensure that the grid size is smaller than the thickness of the sheets, to ensure accuracy.
  • HC202506028620
    0 HC202506028620 over 1 year ago
