  2. Clarity 3D Solver
  3. Do you know the difference between Clarity 3D Layout and...
  • Subscribers 16
  • Views 12147
Do you know the difference between Clarity 3D Layout and Clarity 3D Workbench?
SimTech
SimTech over 4 years ago
Clarity 3D Layout and Clarity 3D Workbench are the latest toolsets offered by Cadence that utilize the Clarity 3D Solver technology.
Cadence® ClarityTm 3D Solver is a 3D electromagnetic (EM) simulation software tool used to analyze critical interconnects for PCBs, IC packages, and System on IC (SoIC) designs. It enables you to handle the most complex electromagnetic challenges when designing systems for 5G, automotive, high-performance computing (HPC), and machine learning applications with gold-standard accuracy.
Clarity 3D Solver uses industry-leading distributed multiprocessing technology from Cadence to deliver virtually unlimited capacity and 10X speed to efficiently and effectively address large and complex structures. It generates highly accurate S-parameter models for use in signal integrity (SI), power integrity (PI), and electromagnetic compliance (EMC) analysis, generating simulation results that match lab measurements, even at 112Gbps+ data transfer speeds. Clarity 3D Solver solves true 3D structures by efficiently matching the available computing resources to the size of the design.
Click here to know more about the Clarity 3D Solvers.
Based on the type of interconnect structures, applications, and the format of the expected result, Clarity 3D Solver is offered in two flavors:
  1. Clarity 3D Layout
  2. Clarity 3D Workbench
Here are the tabulated differences between the Clarity 3D Layout and Clarity 3D Workbench:
Clarity 3D Layout
Solver Engine
Full-wave Clarity 3D
Structure Types
Planar structures: PCBs, IC packages, etc.
Any arbitrary 3D structures
Applications
SI/PI; Planar Antennas; RFICs/MMICs; planar RF/Microwave circuits; Board EMC/EMI
Scattered-wave problems; SI/PI; 2D/3D Antennas; EMC/EMI
Supported CAD Formats
Cadence .mcm, .sip, .brd, gds;
Mentor Graphics BoardStation; Zuken; ODB++; Cadvance; Altium, etc.
Cadence .mcm, .sip, .brd, gds; ODB++; Cadence; AutoCAD; ACIS; STEP; Zuken, etc.
Result Set
S-, Y-, Z-parameters, Current density; E/H Near field; Far field; RLGC equivalent circuits
  • SimTech
    SimTech over 3 years ago
    Take a look at the below link to know more benefits and features of using Clarity 3D Workbench.
    Overview Clarity 3D Workbench
