  2. Clarity 3D Solver
  3. Cut and Stitch Flow in Clarity 3D Layout
  • Subscribers 16
  • Views 10619
SimTech
SimTech over 4 years ago
To speed up the simulation, you can split up a project into several smaller subdesigns and simulate the subdesigns instead. After solving all subdesigns, Clarity 3D Layout stitches each result together to form a whole project solution result. This function is optional and helps reduce the memory and time spent for solving a project.
Before editing a cutting zone:
  • The signal nets for splitting must be selected in Net Manager.
  • The ports must be correctly set in the port setup window, and the number of the ports should be even.
To set up Cut-Stitch Options, click Cut and Stitch Options in the workflow pane. Alternatively, select Tools – Options – Edit Options – Cut and Stitch Options.
The Options dialog is displayed, as shown below.
You can set up the following options here:
  • Automatically launch out models and stitch solutions: If checked, the workflow will automatically solve each cut structure and cascade the S-parameters from each solved model.
  • Edge shape width: Specifies the width of the edge shape. The default is 2 x trace width.
  • Port width: Specifies the port width. The default is 8 x trace width.
  • Port length: Specifies the port length. The default value is the width of the trace.
  • Via diameter: If you select this option, the workflow automatically adds stitching vias from the added shapes to other DC planes or shapes on other layers.
To run a simulation of cut and stitch flow yourself and see the results, click here to access the RAK on Clarity 3D Layout Cut and Stitch Flow.
Team SimTech
Cadence Design Systems
  • SimTech
    SimTech over 3 years ago
    To compare results and run time when the Cut and Stich Flow is applied, have a look at the below article:
    Accelerate your Simulations using Clarity 3D Cut & Stich workflow
