  2. Clarity 3D Solver
  3. Clarity - Tip of the Week - Cylindrical Segmentation in...
  • Subscribers 16
  • Views 1281
Clarity - Tip of the Week - Cylindrical Segmentation in Clarity
SimTech
SimTech over 4 years ago
Typically, when you load a design in Clarity 3D Layout, it might contain several Vias, Wire bonds, circular shapes, Pads, Solder Bumps, Solder Balls etc..
Using the Geometry options, you could reduce the model size.
Sample Layout:
This value will be used to segmentize the cylinder objects
GUIDANCE: Use four points to reduce model size
