  2. Clarity 3D Solver
  3. Aligning far field pattern with User defined work plane...
  • Subscribers 16
  • Views 7892
Aligning far field pattern with User defined work plane Clarity3D Workbench
SimTech
SimTech over 4 years ago
By default, the 3D Far field pattern is displayed at the origin of the WorldCS as shown below.
However, you can also view the 3D pattern at the origin of a user-defined coordinate system (UCS).
To do this, create a simple UCS by selecting WorldCS > Right Click > Add Simple UCS as shown below
Follow the steps to display the 3D pattern at the origin of the UCS.
  1. Display the 3D Far field pattern with geometry.
  2. Click the Align UCS icon  on the tool bar.
  3. Select the SimpleUCS from Align UCS dialog box and Click Apply as shown below.
The 3D Pattern is aligned with point of origin of SimpleUCS.
For more details, please refer Clarity 3D Workbench User Guide Systems Analysis 2022.1 > Running the Simulation > Viewing Simulation Results > Viewing Far-Field Results
Team SimTech
Cadence Design Systems
