  2. Clarity 3D Solver
  3. Clarity – Tip of the Week - Re-use the Mesh in Clarity 3D...
  • Subscribers 16
  • Views 2388
Clarity – Tip of the Week - Re-use the Mesh in Clarity 3D Solver
SimTech
SimTech over 4 years ago
Using the reuse mesh file option, the w3d file in the working directory will be the initial mesh of the new adaptive process
Clarity 3D Workbench:
Go to menu Solver->Analysis Setup->Simulation Options
Clarity 3D Layout:
Go to menu Tools->Options->Edit Options
GUIDANCE: Use it when you need more refined mesh to save time
GUIDANCE: If the max number of adaptive mesh iterations is zero and this option is true, 3D Solver will use the existing mesh as the final mesh to do the frequency sweep.
Team SimTech
Cadence Design Systems
