  2. Clarity 3D Solver
  3. Clarity – Tip of the Week: How to launch Clarity 3D Workbench...
  • Subscribers 16
  • Views 8260
Clarity – Tip of the Week: How to launch Clarity 3D Workbench from Clarity 3D Layout
SimTech
SimTech over 3 years ago
You can use Clarity 3D Layout to analyze PCBs and IC packages and Clarity 3D Workbench to analyze any arbitrary 3D structures. It is possible to launch Clarity 3D Workbench from Clarity 3D Layout, which helps add a connector or cable to the PCB for analysis.
Go to Tools > Launch Clarity3DWorkbench.
Clarity 3D Workbench will open with the PCB geometry as follows:
Now, you can add an SMA connector to the PCB.
Team SimTech
Cadence Design Systems
  • SimTech
    To understand the differences between Clarity 3D Layout and Clarity 3D Workbench you can refer here.
