  2. Clarity 3D Solver
  3. Clarity – Tip of the week: Waveport solve only option in...
  • Subscribers 16
  • Views 4461
Clarity – Tip of the week: Waveport solve only option in Clarity 3D Workbench.
SimTech
SimTech over 2 years ago
For any design with wave ports, it is recommended that you select the Waveport solve only option to ensure that the field behavior at the port interface is as expected, before running a full 3D-EM simulation. The Waveport solve only option solves the 2D Maxwell's equations and calculates the wave port parameters (impedance and propagation constant). You can adjust the wave port size if the fields at the port interface are not as expected to get the correct behavior.
Clarity 3D Workbench:
Go to menu Solver -> Analysis Setup -> Simulation Options
Figure 1, 2, 3 and 4 show fields behavior at port interface, characteristic impedance, Gamma real and Gamma imaginary, respectively.
Figure 1. EM field at port interface (Microstrip)
Figure 2. Transmission line characteristic impedance
Figure 1. Propagation constant – Real part
Figure 4. Propagation constant – Imaginary part
Team SimTech
Cadence Design Systems
