  2. Clarity 3D Solver
  3. Clarity: Tip of the day – Script Recording in Clarity 3D...
  • Subscribers 16
  • Views 4117
Clarity: Tip of the day – Script Recording in Clarity 3D Layout
SimTech
SimTech over 2 years ago
Have you ever found yourself needing to automate an EDA simulation process but struggling to remember all the necessary commands? Well, Clarity 3D Layout has you covered with its Tcl script recording feature!
With this feature, you can easily record, save, and play back your Tcl scripts, making it easier to automate your simulation projects.
Here is how to use the script recording feature in Clarity 3D Layout:
1. Go to Tools > Script Recorder > Record to start recording your scripts.
2. Use the Tools > Script Recorder > Stop command to stop recording.
3. Save the recorded Tcl file by using the Tools > Script Recorder > Save option.
4. To open a recorded Tcl file, click on the Open a Tcl File button.
5. Click on the Play Tcl button to run the loaded Tcl file.
That is it! With this feature, you can streamline your simulation workflow, reduce errors, and increase productivity. Give it a try today and share your experiences and questions in the comments below.
Happy simulating! 
Team SimTech
Cadence Design Systems
