  2. Clarity 3D Solver
  3. [Clarity 3D 23.1.312171.472612 300]: ERROR:MCAD internal...
  • Subscribers 17
  • Views 5306
[Clarity 3D 23.1.312171.472612 300]: ERROR:MCAD internal error
dangminhduc
dangminhduc over 2 years ago
Hello Cadence experts and everyone
I faced an issue with MCAD. I have a file that can run on Clarity 3D version 2021 but when I upgraded to version 2023, this issue happen. I have no idea with it. Please help me.
Here is the output from miscellaneous
Simulation Starts ...
Log into: E:/Project/Project_2024/test_performance/2023/MAIN_240305_CHA_clarity_sim_logs_2024-04-29_10-16-40/MAIN_240305_CHA_run.log
ARGS: None
Starting runloop
240429:031641.277 | atlas_launch | WARNING | Unable to create sylink ./atlas_launch-latest to ./atlas_launch-240429-101641.276 : [WinError 1314] A required privilege is not held by the client: './atlas_launch-240429-101641.276' -> './atlas_launch-latest'
E:\Project\Project_2024\test_performance\2023\MAIN_240305_CHA_clarity_sim_logs_2024-04-29_10-16-40>set /p all_args= 0<"E:/Project/Project_2024/test_performance/2023/MAIN_240305_CHA_all_args_file"
E:\Project\Project_2024\test_performance\2023\MAIN_240305_CHA_clarity_sim_logs_2024-04-29_10-16-40>set CLARITY_CONFIG=E:/Project/Project_2024/test_performance/2023/MAIN_240305_CHA.config
E:\Project\Project_2024\test_performance\2023\MAIN_240305_CHA_clarity_sim_logs_2024-04-29_10-16-40>python C:/Cadence/Sigrity2023.1/ClarityWindowsRunner/Trinity_script/run_atlas_clarity.py --run-dir "E:/Project/Project_2024/test_performance/2023" --design-name "MAIN_240305_CHA.spd" --feature-name FEATURE_V32 --log-dir "E:/Project/Project_2024/test_performance/2023/MAIN_240305_CHA_clarity_sim_logs_2024-04-29_10-16-40" --proxy tcp://192.168.50.168:50099
The long-path-support is enabled in current Windows system.
---------------------------Load CryptUtil on Windows---------------------------
-------------------------Load ClarityLicense on Windows-------------------------
--------------------------Load CryptUtilPub on Windows--------------------------
-------------------------Start license checking program-------------------------
----------------------------Initializing simulation----------------------------
[Elapsed time of last operation: 31.6324 seconds] ERROR:MCAD internal error: 21019 - system inconsistency processing edge coincidence
[Elapsed time of last operation: 1.79869 seconds] ERROR:MCAD internal error: 21048 - unexpected missing attribute on coedge
[Elapsed time of last operation: 0.755523 seconds] ERROR:MCAD internal error: 21034 - inconsistent face-body relationships
[Elapsed time of last operation: 34.3411 seconds] ERROR:MCAD internal error: 21019 - system inconsistency processing edge coincidence
[Elapsed time of last operation: 2.11132 seconds] ERROR:MCAD internal error: 21048 - unexpected missing attribute on coedge
[Elapsed time of last operation: 0.957289 seconds] ERROR:MCAD internal error: 21034 - inconsistent face-body relationships
[Elapsed time of last operation: 353.695 seconds] WARNING:Volume mesh generation failed, terminate the simulation!
---------------------------Re-trying 1: 1 failed jobs---------------------------
[Elapsed time of last operation: 32.5521 seconds] ERROR:MCAD internal error: 21019 - system inconsistency processing edge coincidence
[Elapsed time of last operation: 1.79161 seconds] ERROR:MCAD internal error: 21048 - unexpected missing attribute on coedge
[Elapsed time of last operation: 0.77265 seconds] ERROR:MCAD internal error: 21034 - inconsistent face-body relationships
[Elapsed time of last operation: 32.5789 seconds] ERROR:MCAD internal error: 21019 - system inconsistency processing edge coincidence
[Elapsed time of last operation: 1.945 seconds] ERROR:MCAD internal error: 21048 - unexpected missing attribute on coedge
[Elapsed time of last operation: 0.785748 seconds] ERROR:MCAD internal error: 21034 - inconsistent face-body relationships
[Elapsed time of last operation: 351.353 seconds] WARNING:Volume mesh generation failed, terminate the simulation!
---------------------------Re-trying 2: 1 failed jobs---------------------------
[Elapsed time of last operation: 31.3209 seconds] ERROR:MCAD internal error: 21019 - system inconsistency processing edge coincidence
[Elapsed time of last operation: 1.83863 seconds] ERROR:MCAD internal error: 21048 - unexpected missing attribute on coedge
[Elapsed time of last operation: 0.733871 seconds] ERROR:MCAD internal error: 21034 - inconsistent face-body relationships
[Elapsed time of last operation: 31.8592 seconds] ERROR:MCAD internal error: 21019 - system inconsistency processing edge coincidence
[Elapsed time of last operation: 1.83965 seconds] ERROR:MCAD internal error: 21048 - unexpected missing attribute on coedge
[Elapsed time of last operation: 0.778876 seconds] ERROR:MCAD internal error: 21034 - inconsistent face-body relationships
[Elapsed time of last operation: 351.053 seconds] WARNING:Volume mesh generation failed, terminate the simulation!
---------------------------Re-trying 3: 1 failed jobs---------------------------
--------------------------Failed to distribute 1 jobs--------------------------
[Elapsed time of last operation: 31.1474 seconds] ERROR:MCAD internal error: 21019 - system inconsistency processing edge coincidence
[Elapsed time of last operation: 1.82869 seconds] ERROR:MCAD internal error: 21048 - unexpected missing attribute on coedge
[Elapsed time of last operation: 0.737351 seconds] ERROR:MCAD internal error: 21034 - inconsistent face-body relationships
[Elapsed time of last operation: 31.6905 seconds] ERROR:MCAD internal error: 21019 - system inconsistency processing edge coincidence
[Elapsed time of last operation: 1.80455 seconds] ERROR:MCAD internal error: 21048 - unexpected missing attribute on coedge
[Elapsed time of last operation: 0.793567 seconds] ERROR:MCAD internal error: 21034 - inconsistent face-body relationships
[Elapsed time of last operation: 351.841 seconds] WARNING:Volume mesh generation failed, terminate the simulation!
--Cannot perform meshing using DMesh. Switching the meshing algorithm to LMesh--
-----------------------------1 remote jobs finished-----------------------------
---------------------------------LMesh process---------------------------------
---------------------LMesh: mesh2: 0, 706 mesh3x: 707, 712---------------------
---------------------------Re-trying 1: 3 failed jobs---------------------------
---------------------------Re-trying 2: 3 failed jobs---------------------------
---------------------------Re-trying 3: 3 failed jobs---------------------------
--------------------------Failed to distribute 3 jobs--------------------------
---------------------------Cleanup intermediate files---------------------------
--------------------Post-simulation disk usage: 0.000025 GB--------------------
--------------------------------Release license--------------------------------
-------------------------License checking process exit-------------------------
-------------------------------Simulation failed-------------------------------
E:/Project/Project_2024/test_performance/2023/MAIN_240305_CHA_simulation_error.log
Traceback (most recent call last):
File "C:/Cadence/Sigrity2023.1/ClarityWindowsRunner/Trinity_script/run_atlas_clarity.py", line 16, in <module>
import run_atlas_clarity_impl
File "run_atlas_clarity_impl.pyx", line 30082, in init run_atlas_clarity_impl
File "C:\Cadence\Sigrity2023.1\ClarityWindowsRunner\Python38\lib\asyncio\runners.py", line 43, in run
return loop.run_until_complete(main)
File "C:\Cadence\Sigrity2023.1\ClarityWindowsRunner\Python38\lib\asyncio\base_events.py", line 608, in run_until_complete
return future.result()
File "run_atlas_clarity_impl.pyx", line 25247, in run
File "run_atlas_clarity_impl.pyx", line 11219, in init_mesh_process
File "run_atlas_clarity_impl.pyx", line 11507, in run_init_mesh
File "run_atlas_clarity_impl.pyx", line 11123, in run_init_mesh_imple
File "run_atlas_clarity_impl.pyx", line 10111, in generate_lmesh_partition
File "run_atlas_clarity_impl.pyx", line 10232, in lmesh_submit_jobs_to_atlas
NameError: name 'errStr' is not defined
Simulation finished
  • Sumith
    Sumith over 2 years ago +1
    It looks like there are many MCAD errors that need to be fixed before simulating the geometry. The Clarity 3D Workbench offers different CAD healing options that you can use to fix the geometry. Use Analyze…
  • dangminhduc
    dangminhduc over 2 years ago in reply to Sumith +1
    Thanks Sumith. How can I find the Analyze Entity in Clarity or it is another software? I only faced this error with Clarity 2023, no with Clarity 2021.
  • ShivaShankarM
    ShivaShankarM over 2 years ago in reply to dangminhduc +1
    Hi dangminhduc, The Analyze Entity is available in Clarity 3D Workbench > Healing menu. You can refer the following article for more details. MCAD internal error 21019 Hope it helps.
  • Sumith
    0 Sumith over 2 years ago
    It looks like there are many MCAD errors that need to be fixed before simulating the geometry. The Clarity 3D Workbench offers different CAD healing options that you can use to fix the geometry. Use Analyze Entity to locate the errors and then use CAD Healing options to remove those errors.
  • dangminhduc
    0 dangminhduc over 2 years ago in reply to Sumith
  • ShivaShankarM
    0 ShivaShankarM over 2 years ago in reply to dangminhduc
    Hi dangminhduc,
    Hope it helps.
