  2. Clarity 3D Solver
  3. How display near and far field plots in Clarity 3D Solver...
  • Subscribers 16
  • Views 4584
SimTech
SimTech over 2 years ago
Starting with Clarity 2024.1 Release, the near and far-field results have been consolidated under a common GUI in both Clarity 3D Layout and Clarity 3D Workbench.
The consolidated GUI lets you view the Near Field, 2D Far Field, and 3D Far Field plots which is useful in debugging large and complex structures. You can display the mesh using the following steps.
Near Field:
After the simulation, right-click on Field-Plot from Project > Results and select Field Plot as shown below.
If MagE is the Field option, it will display the E Field as shown below.
You can use the Parts Selector tab to select the metal parts and uncheck parts for better visualization.
Far Field:
In the Field Canvas, choose Far Fields > 3D. Then, right-click 3D and select Add 3D Plot.
It will open the Far Field pattern, as shown below.
Team SimTech
Cadence Design Systems
