  2. Sigrity
  3. How to use POWERDC .SUBCKT in PSPICE simulation
  • Subscribers 22
  • Views 14256
effedipi
effedipi over 6 years ago
I have exracted a resistance network that models one trace on my PCB with PowerDC.
The result is a .ckt file that contains a spice subcircuit with 12 ports.
How can I use this subcircuit in a schematic simulation? I cannot find any documentation...
Thanks a lot
Francesco
  • AvengerThanos
    0 AvengerThanos over 6 years ago
    I think using this subcircuit may not give you accurate results. If you have subcircuit file you need to load the file into model editor and build a model out of it and use the file in schematic simulation. Model editor takes in .ibs file as input. Rename the file to .txt and open with model editor. If it works fine then export the model as library and use in schematics. Hope this helps
  • effedipi
    0 effedipi over 6 years ago in reply to AvengerThanos
    HI AvengerThanos Slight smile
    Indeed what I did was to rename it as .lib, open it wirh model editor and export the component.
    This procedure seems to work fine.
    Francesco
