  2. Sigrity
  3. Does termination resistor on differential pair brought mismatch...
  • Subscribers 23
  • Views 16193
Does termination resistor on differential pair brought mismatch to differential impedance?
Fakhri
Fakhri over 5 years ago
I am working on high speed 8 layer HDI design. My design include differential pairs with 100 ohm diff. impedance. I have 100 ohm termination at receiver side for each of these differential pair.
I have crosschecked the impedance of these line in Cadence impedance workflow  and  observed a impedance mismatch at termination resistor location. The usual value of diff impedance is around 100 ohm while at termination resistor, impedance value around 168 ohm.
Could anyone please suggest any solution or trick to tackle this mismatch?
The resistor has smd 0402 package, does this mismatch will degrade my signal quality?
Many thanks!
  • excellon1
    excellon1 over 5 years ago in reply to Fakhri +1
    In checking your Diff-Pair, I find t is not optimal if one considers ER constant of board say 4 to 5 and variables in the height. Point here is while your math may work out for a certain diff-pair if either…
  • jc teyssier
    jc teyssier over 5 years ago in reply to excellon1 +1
    Application note from Intel: https://www.intel.com/content/www/us/en/programmable/documentation/joc1462311266908.html#joc1463333802645 In order to avoid impedance problems at resistor location you…
  • excellon1
    0 excellon1 over 5 years ago in reply to jc teyssier
    Hi JC
    Excellent write up there from Intel.
    Thanks for sharing
