  2. Sigrity
  3. Sigrity - Tip of the Week: Build a Wire-Based Topology in...
  • Subscribers 21
  • Views 1425
Sigrity - Tip of the Week: Build a Wire-Based Topology in Topology Explorer
SimTech
SimTech over 4 years ago
In Sigrity Topology Explorer, have you ever tried building a wire-based topology for Parallel Bus Analysis and Serial Link Analysis systems? You can achieve that using an option in the Topology Explorer GUI.
When you create a new design in Topology Explorer, by default, the Block-Based option is enabled under the Add Block section.
Uncheck the Block-Based option to build a Wire-Based Topology, as shown below.
