  2. Sigrity
  3. Sigrity-Tip of the week: Record and Save Tcl commands in...
  • Subscribers 22
  • Views 15248
Sigrity-Tip of the week: Record and Save Tcl commands in Sigrity tools
SimTech
SimTech over 4 years ago
Tcl has become the de facto standard embedded command language for Electronic Design Automation (EDA) applications. Whether you need to automate some repetitive behavior, extend the functionality of an application, control multiple tools with a single script, or create a custom GUI, Tcl is your best choice.
To use the Tcl commands in Cadence Sigrity tools, launch the TCL Command editor and choose View > Pane > Tcl Command from the main menu.
As shown below, load a board file in the Power SI Model extraction workflow and observe the Tcl commands that are being recorded in TCL Reader window.
  • jillashiva
    jillashiva over 4 years ago in reply to Raj +1
    Hello Raj Yes Ofcourse you can open the PowerSI in command line and run the recorded scripts, here is the sample [path]/powersi.exe -b -tcl <tcl_script_file.tcl> <layout_file.spd> Cheers, Shiva…
  • Raj
    Raj over 4 years ago
    can we open PowerSI from TCL or Python and run the recorded commands? Do you have any examples?
  • jillashiva
    Hello Raj
    Cheers,
    Shiva Prasad
  • SimTech
    SimTech over 3 years ago
    Further you can refer to the below link on how to invoke and automate Cadence Sigrity tools using TCL script
    support.cadence.com/.../ArticleAttachmentPortal
