  2. Sigrity
  3. SystemSI 17.4 TopXplorer Subckt can't not display power...
  • Subscribers 21
  • Views 3231
SystemSI 17.4 TopXplorer Subckt can't not display power pin
xxxYTU
xxxYTU over 4 years ago
When i use subckt module, if my port only have power and gnd pin, the module will be not display these pins unless assign some power or gnd pin as signal.
I hope to improve in the next patch
  • jillashiva
    jillashiva over 4 years ago +1
    Hello Willy, Right Mouse Click on the Topxp Canvas and select display unconnected Power / Ground option and see if it helps. Best Regards, Shiva
  • xxxYTU
    xxxYTU over 4 years ago in reply to jillashiva +1
    Hi Shiva, Wow..., I got it ! Thank you again. Willy.
  • jillashiva
    0 jillashiva over 4 years ago
    Hello Willy,
    Best Regards,
    Shiva
  • xxxYTU
    0 xxxYTU over 4 years ago in reply to jillashiva
    Hi Shiva,
    Wow..., I got itBlush!  Thank you again.
    Willy.
