  2. Sigrity
  3. Sigrity – Tip of the week: Wondering about the different...
  • Subscribers 21
  • Views 11044
Sigrity – Tip of the week: Wondering about the different file formats that are supported by Sigrity Tool Suite!!
SimTech
SimTech over 4 years ago
Sigrity Suite Manager is a platform that is used to launch Sigrity tools, such as PowerSI, Clarity 3D Layout, Celsius 3D and so on. Sigrity Suite provides a common platform that you can use to work with different Sigrity tools.
Here is the list of File Formats supported by the tools in Sigrity Suite:
  • PowerSI Files (*.spd, *.psix, *.xml, *.dxf, *.brd, *.mcm, *.sip, *.dpf, *.dps, *.txt, *.pcf, *.ftf, *.mrf, *.dsgf, *.sdf, *.sff, *.dbr, *.zip, *.tgz, *.gz, *.z, *.tar, *.7z, *.dsn, *.ndd, *.asc, *.rif, *.sdc, *.pcbdoc, *.cfg)
  • HSSO Files (*.spd, *.hssx)
  • PowerSI Multi Board Files (*.psix)
  • XcitePI XML Files (*.xml)
  • XtractIM Files (*ximx, *.xml, *.spd)
  • PowerDC Files (*pdcx, *.spd, *.sdc, *.xml, *.psix)
  • Celsius Files (*pdcx, *.spd, *.spdx, *.sdc, *.xml, *.psix)
  • PowerDC Multi Board/Package Files (*.sdc)
  • OptimizePI Files (*.opix, *.xml, *.spd)
  • SPEEDEM Files (*.spd, *.dxf, *.brd, *.mcm, *.sip, *.pcf, *.ftf, *.mrf, *.dsgf, *.sdf, *.sff, *.dbr, *.zip, *.tgz, *.gz, *.z, *.tar, *.7z, *.dsn, *.ndd, *.asc, *.rif, *.pcbdoc, *.xml, *.cfg)
  • Layout Files (*.spd, *.log, *.dxf, *.brd, *.mcm, *.sip, *.dpf, *.txt, *.pcf, *.ftf, *.mrf, *.dsgf, *.sdf, *.sff, *.dbr, *.zip, *.tgz, *.gz, *.z, *.tar, *.7z, *.dsn, *.ndd, *.asc, *.rif, *.gds, *.oasis, *.oas, *.xml, *.pcbdoc, *.cfg)
  • SPD Files (*.spd)
  • Allegro Files (*.brd, *.mcm, *.sip, *.dpf, *.dpm, *.dps, *.txt)
  • Translator Log files (*.log)
  • DXF Files (*.dxf)
  • Zuken CR-5000/8000 files (*.pcf, *.ftf, *.mrf, *.dsgf, *.sdf, *.sff)
  • Cadvance Files (*.dbr)
  • ODB++ Files (*.zip, *.tgz, *.gz, *.z, *.tar, *.7z)
  • DSN Files (*.dsn)
  • NDD Files (*.ndd)
  • PADS Files (*.asc)
  • RIF Files (*.rif)
  • GDS Files (*.gds)
  • Oasis Files (*.oasis, *.oas)
  • IEEE Std 2401 M-Format Files (*.xml)
  • Mentor BoardStation Files (*.*)
  • Altium Files (*.pcbdoc)
  • Config Files (*.cfg)
  • IPC2581 Files (*.xml)
  • Workspace XML Files (*.xml)
  • BNP Files (*.bnp)
  • OAMAP Files (*.oamap)
Team SimTech
Cadence Design Systems
