  2. Sigrity
  3. Sigrity – Tip of the week: How to use vendor provided capacitor...
  • Subscribers 21
  • Views 8815
Sigrity – Tip of the week: How to use vendor provided capacitor models from a spreadsheet in Sigrity tools
SimTech
SimTech over 4 years ago
The DecapGenerator utility can be used to convert a spreadsheet-based (.xls, .xlsx) decap library into AMM format. The models must first be put into an Excel spreadsheet using the format below:
The DecapGenerator utility is located in the installation directory <sigrity_install_dir>\tools\bin\DecapGenerator.exe
Follow the steps below to use DecapGenerator.exe:
  1. Launch DecapGenerator.exe.
  2. Select the Source file (.xls) and DecapGenerator will read the header details from the xls, and the fields will be filled in accordingly.
  3. Select the worksheet and the Header row from the source file.
  4. Select the destination file.
  5. Select appropriate column headers from the source file to define the mapping to data fields.
  6. Click the Convert button. The .amm file is created in your working directory.
Team SimTech
Cadence Design Systems
