  2. Sigrity
  3. Tip of the Week - How to update the Trace-End Properties...
  • Subscribers 21
  • Views 1136
Tip of the Week - How to update the Trace-End Properties in an SPD file
SimTech
SimTech over 4 years ago
You can update a trace-end shape to improve its physical connections with other components. You can also update the trace-end shape of a single or multiple traces. Please follow the steps below:
    1. Select the trace in a design.
    2. Right-click and select the Trace<number> from the shortcut menu to open the Trace Properties dialog box. Choose the Round or Flat option from the Starting Node or Ending Node drop-down list.
        One end of the trace becomes flat, as shown below.
        OR
        Right-click and select the Trace End Shape > Round or Flat option from the shortcut menu.
         Both ends of the trace become flat, as shown below.
Team SimTech
Cadence Design Systems
