  2. Sigrity
  3. How to automate Topology Workbench by using Tcl command...
  • Subscribers 21
  • Views 6453
How to automate Topology Workbench by using Tcl commands
SimTech
SimTech over 3 years ago
At times, you need to automate some steps in Topology Workbench like generating a new project, making topology, opening an existing project, making modifications, or running the simulation. When you want to perform the same steps multiple times or set up things for your new designs, you can run the Tcl commands to automate and speed up your work. This is possible with Topology Workbench because it provides Tcl APIs corresponding to the commands you perform in the tool.
Have you noticed that any action you perform in the tool has an equivalent Tcl command and you can see the same in the Command Window?
Similarly, you can also write the Tcl commands in the Command Window to perform an action instead of clicking or filling options.
Some Tcl commands
To create a new project:
newProject <project_name> <design_name> <project_path> sch composite
To open a new project in Top Wb:
openProject <project_path> 1
To add a controller block in a Top-Wb-project-named batch at a specific location:
addBlock Controller -r 0 -mh false -mv false -pg @worklib.batch(tbl_1):Page(1) -rect [list 8600 7640] [list 9000 8040]
If you are interested, check out Topology Workbench Tcl Commands.
Team SimTech
Cadence Design Systems
