  2. Sigrity
  3. Sigrity – Tip of the day – How to define a cable model in...
  • Subscribers 21
  • Views 5989
Sigrity – Tip of the day – How to define a cable model in Topology Workbench
SimTech
SimTech over 3 years ago
The performance of cables needs to be evaluated for better communication between the boards. However, modelling a cable is challenging since the specifications of the cable must be applied carefully. Hence, the simulation tool’s capability to include cable definition is essential for evaluating the channel performance.
In Topology Workbench, you can define cable models for transient or channel simulations. Both Twisted-Pair Cable and Coaxial Cable are supported. You can test the defined cable performance using the Transmitter and Receiver blocks available with the tool.
How do you include cables in your simulation?
Share your inputs on how you model the cables in your simulation.
Team SimTech
Cadence Design Systems
  • SimTech
    Take a look at the below link to know the detailed steps to generate Cable Model:
    How to generate a Cable model and calculate DC resistance in Topology Workbench
