  2. Sigrity
  3. What should I do to make the snp file port name show up...
  • Subscribers 22
  • Views 5892
What should I do to make the snp file port name show up correctly
xianbo
xianbo over 3 years ago
As subject, instead of showing numbers for port names is there a way to show proper port names in sigrity si
Opening the file using text editor does show each ports name, also shows up in ansys edt.
  • JavierAlvarado
    JavierAlvarado over 3 years ago
    Hello Xianbo,
    There are two approaches to accomplish this task, both of them take advantage of the information such as port names and net names usually available in the SNP file generated out of the model extraction.
    1) Modify the Header of the original S-Parameter file.
    2) Create a Spice subcircuit that call your S-Parameter file
    Javier
