  2. Sigrity
  3. why does most of current flow to the center via under a...
  • Subscribers 21
  • Views 4511
why does most of current flow to the center via under a mosfet
GDee1
GDee1 over 2 years ago
the DPAK MOSFET has thermal vias under its main pad, and these thermal vias also are used to connect the copper plane at different layer. The PowerDC analysis shows that most current flows to the center of the vias ( I will say 60% of the total current). This sim result will make impossible to pass sim because the program thinks the current from MOSFET flows from its center to the lower copper plane.
I wish it is caused by my setup. could you please advise?
Thank you.
  • jillashiva
    0 jillashiva over 2 years ago
    You may want to enable 3D via model under Tools options > Advanced otherwise the tool treats it as equipotential
