  2. Sigrity
  3. PCB Designer
  • Subscribers 21
  • Views 6421
PCB Designer
EthanMeng
EthanMeng over 2 years ago
Dear all
I encountered an error while performing impedance workflow simulation.
The parameter {-isCalDiffImpCoplanar} isn't supported.
I hope everyone can provide some assistance.Thank you!!!
  • EthanMeng
    EthanMeng over 2 years ago in reply to geda +1
    The hotfixes I installed are both versions, but I don't know if they match. Where can I check if two versions are compatible?
  • geda
    geda over 2 years ago
    What are the versions of Aurora and Sigrity that are being used at your end? Just to check if this does not arise due to compatibility between versions.
  • EthanMeng
    Cadence 22.1 and Sigrity 22.1
  • geda
    geda over 2 years ago in reply to EthanMeng
    You need to check the base version along with the hotfix version. For ex. I have SPB 22.1 Hotfix S008 & Sigrity 22.1 Hotfix S005.
    SPB 22.1 Hotfix S003 and above is compatible with Sigrity 22.1 Hotfix S005.
    Install the latest hotfixes of both the tools. The latest hotfix versions for 22.1 are shown in the above image.
  • EthanMeng
