  2. Sigrity
  3. A document for Sigrity Aurora 2
  • Subscribers 21
  • Views 10401
RohitRohan
RohitRohan over 2 years ago
Dear Community,
I am planning to start the designs using the Sigrity Aurora 2 software, before that i require a few document about it, can anyone share me some documents on the Sigrity Aurora 2 software.
  • ShivaShankarM
    ShivaShankarM over 2 years ago +2
    Hi Rohit, Currently, There are 11 workflows available in latest Sigrity Aurora II i.e., Virtual Proto Workflow Design Setup Workflow Impedance Workflow Coupling Workflow Crosstalk Workflow…
  • RohitRohan
    RohitRohan over 2 years ago in reply to ShivaShankarM +1
    Dear Shiva Shankar, Thank you for your information, it was very helpful. Regards, Deepak G Krishnan
  • RohitRohan
    RohitRohan over 1 year ago in reply to RohitRohan +1
    Dear ShivaShankar Sir, I hope you are doing well. I have a query regarding Sigrity Aurora. Can we perform PDN analysis using the Sigrity Aurora license? If it is possible, could you kindly…
  • ShivaShankarM
    Hi Rohit,
    1. Virtual Proto Workflow
    2. Design Setup Workflow
    3. Impedance Workflow
    4. Coupling Workflow
    5. Crosstalk Workflow
    6. Reflection Workflow
    7. Return path Workflow
    8. IR Drop Workflow
    9. Power Inductance Workflow
    10. Topology Extraction Workflow
    11. Interconnect Model Extraction Workflow
    To get started, watch the following webinar video about Sigrity Aurora and its workflows.
    Signal and Power Integrity Analysis with Sigrity Aurora
    If you need a RAK or material on any specific workflows, then you can get it from COS (Cadence Online Support) portal.
    For example, click the below COS link for Aurora Topology Extraction Workflow RAK doc.
    Sigrity Aurora: Topology Extraction Workflow
    You can find documents for other workflows in the same COS page.
    Also refer the section ‘Allegro Integrated Analysis and Checking’ in the Allegro user manual below for more details.
    Routing the Design 23.1
    Do you need any more details or material on Aurora?
    Shiva Shankar M
    • Vote Up +2 Vote Down
  • RohitRohan
    Dear Shiva Shankar,
    Deepak G Krishnan
  • RohitRohan
    If it is possible, could you kindly share the steps and procedure to conduct PDN analysis using this tool? Your guidance would be greatly appreciated.
    Looking forward to your response.
    Best regards,
    Rohit Rohan
  • ShivaShankarM
    ShivaShankarM over 1 year ago in reply to RohitRohan
    Hi Rohit,
    I'm doing well. Hope you too.
    Yes, you can use Sigrity Aurora for PDN analysis. You can explore some of the workflows like Impedance workflow, IR Drop workflow, Power Inductance workflow, coupling workflows etc., to get started.
    As mentioned earlier, you can go through the webinar 'Sigrity and Power Integrity Analysis with Sigrity Aurora' for more in-depth understanding of how to run these workflows. This webinar provides a comprehensive overview of the tool's capabilities and will help you get the most out of your PDN analysis.
    Happy learning!
    Cheers,
    Shiva Shankar M
  • RohitRohan
    RohitRohan over 1 year ago in reply to ShivaShankarM
    Hai Sir,
    One doubt, do we use Power Tree to analyze the PDN in the Sigirty Aurora?.
