  2. Sigrity
  3. How to create Power Nets / GND Nets and VRMs for the PCB...
  • Subscribers 21
  • Views 6321
How to create Power Nets / GND Nets and VRMs for the PCB design for Sigrity Power DC Simulation
RohitRohan
RohitRohan over 2 years ago
Dear Community,
Currently I have a PCB BRD file for which I want to calculate the IR drop, Current density and Voltage drop, but when I try to import the PCB board file to the Sigrity Power DC, I see there are no Power / GND Nets defined, and the VRMs are also not defined, how to create the Power Nets and VRMs for the PCB design.
Rohit Rohan
  • jillashiva
    0 jillashiva over 2 years ago
    The net definitions for a signal/power/ground should be defined in a layout design tool, and then translated into a signal environment. However, you can right-click on the required net and classify it as power/ground net.
    For the VRM definition, follow the work flow > Setup VRM in Power DC
    Shiva Prasad Jilla
  • RohitRohan
    0 RohitRohan over 2 years ago in reply to jillashiva
    Hai Shiva,
    One doubt, is it in schematic capture we have to select the net and right-click then define the net as signal / power and ground?.
    Rohit Rohan
  • jillashiva
    0 jillashiva over 2 years ago in reply to RohitRohan
    you could do the signal / power and ground net classification in powerdc netmanager as well..
