  2. Sigrity
  3. Output File Paths
  • Subscribers 21
  • Views 2694
Output File Paths
LL202408212637
LL202408212637 over 1 year ago
When I run a powersi simulation, all the files get dumped in my current working directory where I execute the batch mode commands to run powersi. Is there a way to change the way powersi dumps the files so that I can store the log files in a specific folder, the spd files in a specific folder, etc? I am using a python script to import an options file but I'm not sure if the file paths within the file manager section of the xml are compatible with relative paths, they are only using absolute paths.
  • CadAP
    0 CadAP over 1 year ago
    LL202408212637
    please try the below command:
    import os
    new_directory = "<path_to_newlocation>"
    os.chdir(new_directory)
    Once directory changed try to run you python command to see it generate files at the new directory location.
