  2. Sigrity
  3. Set up OptimizePI
  • Subscribers 21
  • Views 4018
Set up OptimizePI
KN202502107649
KN202502107649 11 months ago
Hi everyone,
I’m running a PDN simulation for the VDD rail on my board and I’m not sure how to set up the VRM model and the impedance observation in OptimizePI.
On my board the VDD rail is split into two net names:
  • VDD_MB: this comes from a connector and gets power from another power board.
  • After the connector the power goes through resistor R10.
  • VDD: this is the net after R10 and it powers the load IC (U1).
So the topology is:
external VRM → connector → net VDD_MB → R10 → net VDD → U1.
My questions:
  1. For this topology, should I assign the VRM model to VDD_MB or to VDD in OptimizePI?
  2. For impedance observations, is it enough to create one observation at U1_VDD_GND, or should I also create an observation at the connector/net VDD_MB?
Any suggestions or example setups would be greatly appreciated.
Thank you very much,
Kaydee
  • Sumith
    Sumith 11 months ago +1
    Hi Kaydee, you can model the VRM at the starting point of the net VDD_MB and set the observation point at U1_VDD_GND. Additionally, you may need to ensure a return path exists for accurate impedance calculation…
  • Sumith
    0 Sumith 11 months ago
    Hi Kaydee, you can model the VRM at the starting point of the net VDD_MB and set the observation point at U1_VDD_GND. Additionally, you may need to ensure a return path exists for accurate impedance calculation.
  • KN202502107649
    0 KN202502107649 11 months ago in reply to Sumith
    Hi Sumith
    Tool / version
    • Sigrity 19.0, OptimizePI flow
    • Board has been used in PowerDC already and DC path is correct.
    Topology
    • External power board provides VDD through a connector J5 on my board.
    • Net from connector is called VDD_MB.
    • From J5 the power goes through two resistors R10 (DCR ≈ 0.2 mΩ each) to the net VDD.
    • Net VDD powers the main IC U1.
    • So the path is: external VRM → J5 (VDD_MB) → R101/R102 → VDD → U1.
    OptimizePI setup (follow your guideline)
    1. In Net Manager / P-G classification wizard, both VDD_MB and VDD are classified as PowerNets, GND as GroundNet.
    2. In Define VRM Models, I created a VRM model and assigned:
      • Power net = VDD_MB
      • Return net = GND
    3. In Impedance Observations, I created two observation points:
      • J5_VDD_MB_GND
      • U1_VDD_GND (Model Name = @Open@)
    4. Analysis type = What-If, frequency range 100 kHz – 1 GHz.
    Problem / plot
    • The self-impedance at J5_VDD_MB_GND (red curve) is flat and very low (~1 mΩ) across the whole band, which looks like the VRM impedance – this seems correct.
    • But the self-impedance at U1_VDD_GND (blue curve) starts at very high impedance (~10³ Ω) at low frequency and then decreases with 1/ω, with a resonance dip around a few hundred MHz.
    • This shape looks like “no VRM connected, only planes + decaps”.
    • In other words, from the U1 node OptimizePI appears not to “see” the VRM at J5, even though in the physical design they are connected through R101/R102 and I can simulate DC IR drop in PowerDC.
    Question
    What is the correct way to set up the VRM and nets so that the VRM at VDD_MB is seen from the load node U1_VDD_GND?
    • Do I need to do anything special in Select Nets / PowerTree in this older (19.0) OptimizePI flow to make VDD_MB and VDD part of the same rail?
    • Could component filtering be removing R101/R102 or otherwise breaking the connection between VDD_MB and VDD in the OptimizePI circuit?
  • KN202502107649
    Hi Sumith
    Tool / version
    Topology
      • Return net = GND
      • J5_VDD_MB_GND
    Problem / plot
    Question
  • KN202502107649
    Thank you very much @Sumith
    Topology
    • From J5 the power goes through two resistors R10(DCR ≈ 0.2 mΩ each) to the net VDD.
    OptimizePI setup (follow your guild line)
      • Return net = GND
      • J5_VDD_MB_GND
      • U1_VDD_GND
    Problem / plot
    • In other words, from the U1 node OptimizePI appears not to “see” the VRM at J5, even though in the physical design they are connected through R10 and I can simulate DC IR drop in PowerDC.
    Question
  • KN202502107649
    Thank you very much Sumith,
    Topology
      • Return net = GND
      • J5_VDD_MB_GND
      • U1_VDD_GND
    Problem / plot
    Question
