  2. Sigrity
  3. Power SI - Query on Retrieving Connected Objects from a...
  • Subscribers 21
  • Views 2600
Power SI - Query on Retrieving Connected Objects from a Net in PowerSI 2021.1 Using TCL
ABIKRISHNA
ABIKRISHNA 10 months ago
Hello Team,
              I am currently working on automating a task in PowerSI 2021.1 using a TCL script. I would like to retrieve all objects connected to a given net or any other objects, similar to how we use axlDBGetConnect in Allegro.
Specifically, when I provide a net name, I want the script to return all connected elements such as:
  • Vias
  • Components / pins
  • Traces / clines / shapes
In Allegro, axlDBGetConnect allows us to easily find all elements connected to a given DBID. I am looking for an equivalent or recommended approach in Sigrity PowerSI TCL to obtain this connectivity information.
Could you please let me know:
  • If there is a direct TCL API or command in PowerSI to query all objects connected to a net
  • Or, if not, what is the recommended workflow to extract this connectivity data programmatically
  • ShivaShankarM
    ShivaShankarM 10 months ago +1
    Hi ABIKRISHNA, You can try below TCL to get details like Trace, via, Node, components, shapes etc., for a particular net. sigrity::showObjectsofNets -nets {<Net_Name>} {!} I've tried it in PowerSI…
  • ShivaShankarM
    0 ShivaShankarM 10 months ago
    Hi ABIKRISHNA,
    I've tried it in PowerSI v25.1 release and got expected results, so you can try it in v21.1 release to see how it goes.
    Shiva Shankar M
  • ABIKRISHNA
    0 ABIKRISHNA 10 months ago in reply to ShivaShankarM
    Hello Shiva Shankar M,
    Thank you for your response.
    We tried this method, but unfortunately it works only in PowerSI 25.1. In PowerSI 2021.1, the command does not seem to be available / does not return the required connectivity information.
    Our actual requirement is the following:
    • The user provides one or more net names
    • From the given nets, we need to identify all connected vias
    • From those vias, we need to detect backdrilled vias
    • Finally, we need to remove the backdrill irrespective of topology (point-to-point, multi-drop, plane connections, etc.)
    Since sigrity::showObjectsofNets is not supported in 2021.1, could you please advise:
    1. Is there any alternative TCL API in PowerSI 2021.1 to retrieve vias connected to a given net?
    2. Is there a recommended workflow in older PowerSI versions to identify backdrilled vias programmatically?
    3. Are there any examples or internal commands available in 2021.1 for backdrill detection/removal?
    Any guidance specific to PowerSI 2021.1 would be greatly appreciated.
    Thanks and regards,
    Abikrishna.
