  2. Sigrity
  3. Can Cadence Sigrity PowerSI help analyze the combined package...
  • Subscribers 21
  • Views 99
Can Cadence Sigrity PowerSI help analyze the combined package and PCB design for signal and power integrity issues?
cistheta07
cistheta07 2 days ago
Hi everyone,
We are designing a high-speed PCB with a complex IC package and are experiencing unexpected power-supply noise and voltage fluctuations. We suspect that package parasitics, BGA connections, and PCB power/ground structures may be affecting the overall PDN impedance and contributing to power-supply noise.
Currently, our IC package and PCB layouts are available as separate design files. We would like to perform power integrity analysis across the complete package-board interconnect to understand how these structures collectively affect power delivery.
Can Cadence Sigrity PowerSI help us analyze the combined package and PCB design, extract S-parameters for the interconnect, evaluate frequency-dependent PDN impedance, identify potential impedance peaks and resonance issues, and assess the effectiveness of our existing decoupling capacitor placement?
Thank you in advance!
  • StephenNewberry
    StephenNewberry 2 days ago +1
    Yes, absolutely! It's possible to merge two SPD files with a BGA ball definition in between. If you don't yet know your PCB layout, you can merge a "Pseudo PCB" to still include the parasitics of the BGA…
  • cistheta07
    cistheta07 2 days ago in reply to StephenNewberry +1
    Hi Stephen, Thank you so much for the quick and helpful response! Good to know about merging the two .spd files via Edit -> Merge with the BGA ball definition, as well as the "Pseudo PCB" option for…
  • StephenNewberry
    0 StephenNewberry 2 days ago
    Yes, absolutely! It's possible to merge two SPD files with a BGA ball definition in between. If you don't yet know your PCB layout, you can merge a "Pseudo PCB" to still include the parasitics of the BGA balls. Check the Edit->Merge menu
  • cistheta07
    0 cistheta07 2 days ago in reply to StephenNewberry
    Hi Stephen,
    Thank you so much for the quick and helpful response! Good to know about merging the two .spd files via Edit -> Merge with the BGA ball definition, as well as the "Pseudo PCB" option for early package-level analysis. We will check that out right away.
    Thanks again!
