Markerserver module error
 I am using Pspice 9.1 Std. ver. on vista. When I want to put a probe on my circuit design programme closes. At first it give an error named "Markerserver module has stopped working" and after that when I try to put a probe it always closes. I do not know it is the problem but in short I can't do any simulation. Plz Hlp!
 Best Regards
  • OrCAD PSpice 9.1 was certainly not tested on Vista, I suspect that Vista is crippling this application. You probably need to get an upgrade!
CDNS Forum Thread CSS JS
CDNS - Fix Layout
