TSMC 0.18 PDK and Cadence IC 6.1.3
 Greetings,
 Our institution just got the .18 PDK from MOSIS. I converted it to OpenAccess format.
However when I try to load any schematic/layout I get the following errors:
</p><p>..... Initializing ipTag.ile from libInit.il for library tsmc18rf...
Loading awv.cxt
Loading oasis.cxt
Loading analog.cxt
Loading asimenv.cxt
Loading spectrei.cxt
Loading spectreinl.cxt
ERROR (ADE-5066): Tool 'hspiceS' has not been registered.
ERROR (ADE-5067): Unable to initialize tool 'hspiceS'; either tool class is not
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; defined or tool is not registered.
*Error* The default SKILL generic function has not been defined for the function &quot;asiEnvGetVar&quot;. Ensure that this function is called with the correct argument(s) (tool partition name).
Loading schematic.cxt
Loading lo.cxt........</p><p>
Can I do anything about this?
I noticed that the 'Tool' menu does not show up anymore in the schematic/layout editor.
Any help would be appreciated!
Thanks!
CDNS Forum Thread CSS JS
CDNS - Fix Layout
