Cadence server error when logging in
I get this a lot...like almost all of the time.  Can you look into it?
Server Error in '/Community' Application.
Object reference not set to an instance of an object.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Line 158:            >
Line 159: <ModeratedSuccessActions>
Line 160: <CSControl:GoToSiteUrlAction ID="GoToSiteUrlAction1" UrlName="post_PendingModeration" Parameter1='<%# CurrentSection.SectionID %>' runat="server" />
Line 161: </ModeratedSuccessActions>
Line 162: <UnmoderatedSuccessActions>
Source File: c:\Cadence\CommunityServer\Web\Themes\default\Forums\createeditpost.aspx    Line: 160
Stack Trace:
[NullReferenceException: Object reference not set to an instance of an object.]
ASP.themes_default_forums_createeditpost_aspx.__DataBindingGoToSiteUrlAction1(Object sender, EventArgs e) in c:\Cadence\CommunityServer\Web\Themes\default\Forums\createeditpost.aspx:160
System.Web.UI.Control.OnDataBinding(EventArgs e) +99
System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +92
System.Web.UI.Control.DataBind() +15
System.Web.UI.Control.DataBindChildren() +211
System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +102
CommunityServer.Controls.WrappedFormBase.DataBind() +118
CommunityServer.Discussions.Controls.CreateEditForumPostForm.DataBind() +52
CommunityServer.Controls.WrappedFormBase.OnLoad(EventArgs e) +28
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Control.LoadRecursive() +141
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.3082; ASP.NET Version:2.0.50727.3082
CDNS Forum Thread CSS JS
CDNS - Fix Layout
