forum issue
Hi
Today I've experienced the following error with some posts that I've made (includes attached file and tag) - if the post is created only using text there is no issue. Viewing some of the posts also exhibits this issue.
Post from other user with this error: /forums/T/14614.aspx
Posts from me: /forums/T/14631.aspx and /forums/T/14605.aspx - problem showed up at post click
Any ideas what the problem is?
Ole
Server Error in '/Community' Application.
Logon failure: unknown user name or bad password.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IO.IOException: Logon failure: unknown user name or bad password.
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[IOException: Logon failure: unknown user name or bad password.
   System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath) +7714920
   System.IO.Directory.InternalCreateDirectory(String fullPath, String path, DirectorySecurity dirSecurity) +7567177
   System.IO.DirectoryInfo.Create() +15
   CommunityServer.Components.Globals.SaveToDisk(Stream content, String name) +88
   CommunityServer.Configuration.AttachmentSettings.SaveToDisk(PostAttachment pa, String name) +32
   CommunityServer.Configuration.AttachmentSettings.SaveAttachmentToDisk(PostAttachment pa, Int32 sectionID, Int32 postID) +62
   CommunityServer.Configuration.AttachmentSettings.DirectPath(PostAttachmentMetaData metaData) +109
   CommunityServer.Discussions.Components.ForumUrls.PostAttachment(Int32 postID) +126
   CommunityServer.Discussions.Controls.PostAttachmentData.GetHyperLink() +178
   CommunityServer.Controls.ObjectDataBase.GetContentTemplateWrapper() +25
   CommunityServer.Controls.ObjectDataBase.AddContentControls() +99
   CommunityServer.Controls.WrappedContentBase.CreateControlHierarchy() +107
   CommunityServer.Controls.WrappedContentBase.CreateChildControls() +32
   CommunityServer.Controls.WrappedContentBase.OnDataBinding(EventArgs e) +44
   System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +92
   System.Web.UI.Control.DataBind() +15
   CommunityServer.Controls.WrappedContentBase.DataBind() +104
   CommunityServer.Controls.ObjectDataBase.DataBind() +40
   System.Web.UI.Control.DataBindChildren() +211
   System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +102
   System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem) +124
   System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource) +443
   CommunityServer.Controls.WrappedRepeater.CreateControlHierarchy(Boolean useDataSource) +145
   CommunityServer.Controls.PreTemplatedWrappedRepeaterBase.CreateControlHierarchy(Boolean useDataSource) +372
   System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e) +51
   CommunityServer.Controls.WrappedRepeater.OnDataBinding(EventArgs e) +14
   System.Web.UI.WebControls.Repeater.DataBind() +75
   CommunityServer.Controls.WrappedRepeater.DataBind() +104
   CommunityServer.Controls.PreTemplatedWrappedRepeaterBase.DataBind() +12
   CommunityServer.Controls.PreTemplatedWrappedRepeaterBase.OnLoad(EventArgs e) +31
   System.Web.UI.Control.LoadRecursive() +50
   System.Web.UI.Control.LoadRecursive() +141
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Version Information: Microsoft .NET Framework Version:2.0.50727.3082; ASP.NET Version:2.0.50727.3082
  •  Hi Ole,
     Could you try this again and see if it works?
    David
    Community Manager
  • Hi David
    I still get the same error (or similar looking) accessing any of the 3 posts mentioned
    Best regards
    Ole
CDNS Forum Thread CSS JS
CDNS - Fix Layout
