Posts need to be approved by moderator?
I noticed recently that when I reply to a thread that it must first be approved by a mod... then the post never seems to be approved. I've tried reposting but same result. I'm guessing this a problem with the approval mechanism because I don't see why thanking someone for solving my problem wouldn't receive approval.
  •  Hi tkhan,
     The forum posts are "post moderated" so you should see your reply right after posting.   Which forum did you post in and when?
    David
  • Hi David,
    I was replying to my thread in Custom IC Design (http://www.cadence.com/community/forums/T/14511.aspx). I was able to mark the thread as "Answered", but twice I tried posting a reply a few days apart with no luck. I noticed someone else had the same problem, but Andrew said there were not posts needing moderation:  http://www.cadence.com/Community/forums/p/14387/25050.aspx#25050
    Tarek
  •  Hi Tarek,
     Could you try again.  Some issues have just been fixed.
    David
  • Hi David
    I have been getting the same error for the following post too. I cannot reply to it.
    http://www.cadence.com/community/forums/T/14696.aspx
    Please see the uploaded picture. I had the same problem with another post but it went away after a day.
    Quek
  • We believe some posts got tagged as needing moderation because of a spam blocker config change we made.  It should be corrected now.
    Sorry for the inconvenience.
    communityops
CDNS Forum Thread CSS JS
CDNS - Fix Layout
