Dimension parameters
Anyone know of a way to update dimensioning parameters of existing dims? Our company changed standards and I'm checking to see if there is a way to open an existing file and apply the new parameters without having to delete and regenerate all the dimensions. Need to update all leader lines as well.
Cadence Sip Digial Layout GXL 16.3
 .........Donnie
  • Open the database then export parameters in 16.3.
    The export functionality creates the parameter file (with a .prm file extension). The parameter file contents can be the following options.
    • Design Setting ( Global values and grid settings)
    • Artwork (Artwork film, film block and film class)
    • Color (Color parameter and color table)
    • Text Size (Text size table)
    • Application or Command Parameters (All the other supported parameters)
    Once you've exported parameters from an exiting board file, they an be imported into a new board file using the Board Wizard
    Best regards,
    -oscar
CDNS Forum Thread CSS JS
CDNS - Fix Layout
