Hi source library?
 Hi everyone,
I know this question sound silly. But I'm a new user of pspice. Therefore I have a problem in finding one of the part that I needed. In which library can I found the High source? I don't know if i can call it high source because I dont really know the exact name. The model looks like digital source model but with 'HI' in it. I want to use it to make my set and reset at d-ff always 1.
Thanks in advance.
  • Wow. It's working now. I didn't know there are difference between regular Capture library and Pspice library.Thank you for your help:)
  •  Hi,
    I've a question. Right now the output of the XOR, Usat+ is around 3.7V and Usat- is around 0.2V.  For my circuit Usat+ should be 2V and Usat- should be 1V. How can I control the Usat+ and Usat- of XOR output? Is there any trick do it?
CDNS Forum Thread CSS JS
CDNS - Fix Layout
