Where do I ask PSpice questions?
What forum do I ask PSpice A/D usage questions in? I didn't see a forum for software questions in the list.
 Thanks.
  •  You may post your PSpice related questions under "PCB Design Forum".
  • Well *that's* certainly obvious. You'd think for $3800 they'd at least have intuitively named forums. The software is bad enough already.
  • I am currently unable to access the forum list due to the following error, which I have received for about an hour. I can only post in threads I have a direct URL for, such as this one (via the response email):
    Server Error in '/Community' Application.
    Specified cast is not valid.
    Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
    Exception Details: System.InvalidCastException: Specified cast is not valid.
    Source Error:
    An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
    Stack Trace:
    [InvalidCastException: Specified cast is not valid.]
       CommunityServer.Components.Profile.get_EnablePostPreviewPopup() +37
       CommunityServer.Discussions.Controls.ThreadData.GetHyperLink() +219
       CommunityServer.Controls.ObjectDataBase.GetContentTemplateWrapper() +25
       CommunityServer.Controls.ObjectDataBase.AddContentControls() +99
       CommunityServer.Controls.WrappedContentBase.CreateControlHierarchy() +107
       CommunityServer.Controls.WrappedContentBase.CreateChildControls() +32
       CommunityServer.Controls.WrappedContentBase.OnDataBinding(EventArgs e) +44
       System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +92
       System.Web.UI.Control.DataBind() +15
       CommunityServer.Controls.WrappedContentBase.DataBind() +104
       CommunityServer.Controls.ObjectDataBase.DataBind() +40
       System.Web.UI.Control.DataBindChildren() +211
       System.Web.UI.Control.DataBind(Boolean raiseOnDataBinding) +102
       System.Web.UI.WebControls.Repeater.CreateItem(Int32 itemIndex, ListItemType itemType, Boolean dataBind, Object dataItem) +124
       System.Web.UI.WebControls.Repeater.CreateControlHierarchy(Boolean useDataSource) +443
       CommunityServer.Controls.WrappedRepeater.CreateControlHierarchy(Boolean useDataSource) +145
       CommunityServer.Controls.PreTemplatedWrappedRepeaterBase.CreateControlHierarchy(Boolean useDataSource) +372
       System.Web.UI.WebControls.Repeater.OnDataBinding(EventArgs e) +51
       CommunityServer.Controls.WrappedRepeater.OnDataBinding(EventArgs e) +14
       System.Web.UI.WebControls.Repeater.DataBind() +75
       CommunityServer.Controls.WrappedRepeater.DataBind() +104
       CommunityServer.Controls.PreTemplatedWrappedRepeaterBase.DataBind() +12
       CommunityServer.Controls.PreTemplatedWrappedRepeaterBase.OnLoad(EventArgs e) +31
       System.Web.UI.Control.LoadRecursive() +50
       System.Web.UI.Control.LoadRecursive() +141
       System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
    Version Information: Microsoft .NET Framework Version:2.0.50727.3625; ASP.NET Version:2.0.50727.3634
  • I am still receiving this same error. It is consistent. It can only be resolved by logging out.
    When I log out I can view the forums. When I log in I cannot.
    The only way for me to post is to log out, navigate to the post I want to reply to, hit the reply button, and then log in from there and continue, after which I must log out again to view the forums.
    It appears Cadence tests their web site as well as they test their software.
CDNS Forum Thread CSS JS
CDNS - Fix Layout
