This search text may be transcribed, used, stored, or accessed by our third-party service providers per our Cookie Policy and Privacy Policy.
Hello all,
I've have downloaded and installed ORCAD 16.6 Lite but I get the following error when I start a PSPICE simulation:
"ERROR(15053): Can not initialize PSpice UI"
Does anyone know why this happens and how to solve it?
Hi there,
I have the same issue under Windows XP SP3 and I find out that I can't invoke pspice from the start menu. You rename %HOME%/CDSSETUP to what ? I found the variable in the windows system variables but also in some Orcad ini files too. Orcad was installed in a virtual partition D:\ and the %HOME%/CDSSETUP points to the right place that is D:\Windows Section\OrCAD_16.6_Lite which is the installation folder I choose when installing Orcad so everything seems to be correct for me and there is only one user account on my computer.
I have uninstalled it and reinstalled it in the default directory C:\OrCAD\OrCAD_16.6_Lite\ and it is the same problem
OrCAD Capture CIS Lite -> no problem Magnetic Parts Editor -> no problem Model Editor -> error message: This application has quit unexpectedly. To help Cadence detect and analyse the problem archive the current project...Simulation Manager -> no problemStimulus Editor -> error message: This application has quit unexpectedly. To help Cadence detect and analyse the problem archive the current project...PSpice Advanced Analysis Lite -> no problemPSpice AD Lite -> nothing happen !
Any ideas !
Thank you, bye.
Rename %HOME%/cdssetup folder to anything, that won't matter. Goal is to remove "cdssetup" folder from %HOME%, so that a new one gets created on invocation.
