An Error During the Simulation
Hello, i am both newbie in this forum and OrCAD. I need to simulate the circuit as shown below but i have a problem in Pspice:
INFO(ORPROBE-3183): Simulation running...
** Profile: "SCHEMATIC1-Full-Bridge"  [ D:\Electrical & Electronics\Power Electronics\Simulation & Schematics\Orcad\full-bridge-pspi
Reading and checking circuit
ERROR(ORPSIM-16276): Can't find library
Circuit has errors ... run aborted
See output file for details
INFO(ORPROBE-3188): Simulation aborted
I am using UC3825 but it also says as follows:
WARNING(ORNET-1018): Connection to unmodeled pin U8 pin 'RT'
WARNING(ORNET-1018): Connection to unmodeled pin U8 pin 'CT'
 Schematic: http://oi62.tinypic.com/qrdjzo.jpg
  • Check the path for all configured libraries under Simulation profile>Configure files TAB. Above error indicates that one or more library files configured, under simulation profiles are missing.
  • what do you mean about the above errors?
    i too am currently experiencing errors. i tried to run the Demo_samples but the error still exists.:
    ** Creating circuit file "transient.cir"
    ** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
    *Libraries:
    * Profile Libraries :
    * Local Libraries :
    * From [PSPICE NETLIST] section of C:\pcblib\apps\allegro\SPB_16.5\tools\PSpice\PSpice.ini file:
    .lib "adi_pspice.lib"
    .lib "nom.lib"
    *Analysis directives:
    .TRAN  0 1 0 1m
    .PROBE V(*) I(*) W(*) D(*) NOISE(*)
    .INC "..\SCHEMATIC1.net"
    **** INCLUDING SCHEMATIC1.net ****
    * source BPF
    X_U5         0 N14003 VCC VEE OUT uA741
    V_V4         IN 0  AC 1
    +SIN 0 1 10 0 0 0
    V_V5         VCC 0 15v
    V_V6         VEE 0 -15v
    R_R15         N30040 IN 10k
    R_R16         N14033 N30040 5k
    C_C5         N14033 N14003 2u TC=0
    C_C6         OUT N14033 1u TC=0
    R_R17         N306200 N14033 620
    R_R18         0 N306200 5k
    R_R19         N14117 N14003 220k
    R_R20         N14117 OUT  1k
    R_R21         N14117 0 R_R21 1k
    .model        R_R21 RES R=1 DEV=10%
    **** RESUMING transient.cir ****
    .END
CDNS Forum Thread CSS JS
CDNS - Fix Layout
