This search text may be transcribed, used, stored, or accessed by our third-party service providers per our Cookie Policy and Privacy Policy.
When accessing simvision via VPN, when I try to drag and drop a signal in the waveform window the application gets hung up. If I go to the mouse connected directly to the workstation I can complete the drag and drop using a middle button click, but I'm unable to complete using the mouse connected to the system from which I'm accessing simvision via VPN. When this happens I am unable to do anything on the workstation remotely and must complete the operation on the workstation itself.
Has anyone seen this and (other not dragging and dropping a signal) how can it be corrected remotely? Thanks! Mark
