Problem footprint
Hi, I'm new in Allagro Orcad.
I have encounter a problem.
When in the Page1 I click "show footprint" in the log session appear this:
"WARNING(SPMHUT-127): Could not find padstack PAD_105_BLUETH-1. ERROR(SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file. Unable to opening design PCB_CC2564MODA.psm"
"WARNING(SPMHUT-127): Could not find padstack PAD_LDO-1. ERROR(SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file. Unable to opening design PCB_LDO.psm"
"WARNING(SPMHUT-127): Could not find padstack PAD_LS-1. ERROR(SPMHA1-161): Cannot open the design database file ... run standalone dbdoctor on the file. Unable to opening design PCB_LS.psm"
I have already pasted the .dra, .psm and .pad in the symboIs folder but still doesn't work
In my project i have several components, infact only with this 3 components i have the problem. Can someone help me?
Than You for your help
  • I would double check the psm path is to the folder you placed it in.
CDNS Forum Thread CSS JS
CDNS - Fix Layout
