  2. Functional Verification
  3. how to merge the coverage report using IMC?
  • Subscribers 70
  • Views 41514
guest4cadence
guest4cadence over 14 years ago
Hi All,
I am running the tests using the VIPP OVM using irun. I am able to dump the icc*.ucd. Also, I am able to open the coverage of each test using the IMC gui and not ICCR.
But, when it comes to merge IMC doesn't support the gui mode merge. Can some1 help me how to merge and generate the coverage report.
  • smubarak
    smubarak over 14 years ago
     I am trying to merge my coverage results from regrssion with imc or iccr , but the tool gives some error even for a simple packet example.
    IMC: getting error : "Data projrction failed "
    ICCR: failed due to mismatch in design checksum with the loaded model file "cov_work/scope/icc70938af1_63e43f52.ucm".
    options used :-
    irun test1.sv -covtest  test1 -coverage all covdut test1
    imc -batch imc.cmd
    imc.cmd:-
     merge cov_work/scope/test* -out result  [ ERROR: Data projection failed , when laoding 2nd test]
    Can You please help me on this.
    Siraj
  • smubarak
    options used :-
    imc -batch imc.cmd
    imc.cmd:-
    Siraj
