  3. Cellview empty space
  • Views 18264
psill
psill over 13 years ago
 I have a cellview I created with XL and I can not minimize the empty space so when I view the layout it shows only the drawn objects.
What I have done to minimize or delete the empty space.
1) All layers valid, select all, deselect object to keep, delete.
2) Zoomed way out draw a rectangle then delete object.
3) Turned on all markers viewable and selectable.
Last resort to try, recreate layout.
I would prefer not to recreate the layout since I have synchronousClone and some symmetry in the layout
Is there a system layer I dont see or cant select causing the problem.
  • psill
    Yes, the problem was the steiners causing my cellview to larger than the layers showed.
    Thanks for your help
  • psill
