  3. How to obtain Discrete-Time (DT) response from a switched...
  • Replies 52
  • Subscribers 131
  • Views 35408
How to obtain Discrete-Time (DT) response from a switched-cap (SC) circuit (integrator)?
bernd2700
bernd2700 over 3 years ago
Hello everybody!
Before I start my questions, first I have to cite from Mr. Ken Kundert’s excellent paper “sc-filters  -  Simulating with Cadence SpectreRF” the following: “Usually, with switched-capacitor circuits, designers are interested in the discrete-time behavior as switched-capacitor filters are embedded in sampled-data systems. SpectreRF is set up to report on the continuous-time behavior. As such, you must take steps to get the discrete-time behavior if that is what you need. The PNoise analysis does provide a built-in feature that can be invoked in order to determine the noise of a filter acting as a discrete-time system. Otherwise you will need to add a idealized sample-and-hold to your circuit.”
He wrote to me at forum “designers-guide.org/.../YaBB.pl” the following: “I'm afraid I have no experience with sampled PAC”, because this was implemented later. So I count on you, Cadence guys that hopefully YOU have an answer to me:
Q1: I thought (wrongly) I would obtain the DT response of a system if I specify the special option “SAMPLED” of SpectreRF Periodic-AC (PAC). This is not the case. So, if anyone please could tell me what to do to get the DT frequency response for the PAC analysis? (see graphs below)
Q2: Do YOU have an idea which feature can be invoked to obtain the DT system response in the PNoise analysis? As you see above, Ken Kundert indicated so, but did not say which feature. Once, he wrote to me: “I think they confused autonomous sampling (sample very T seconds) and triggered sampling (sample at a threshold crossing), and assumed that triggered sampling in PNoise was enough”.
Ad Q1:
You see an CT (Conttinuous-Time) analog Low-Pass-Filter (LPF) which is simulated with Cadence SpectreRF PAC _sampled and the result of it below.
Ok, this time, it's not a SC circuit, but this is not the topic. It rather is: How to obtain the Bode diagram of the _DT_ response of any circuit.
You can recognize the obtained spectrum is NOT symmetrical around half the sampling frequency fs/2, as I was expecting, but it still seems to show the CT response.
Many thanks in advance and best regards,
bernd2700
  • SpiceMonkey
    SpiceMonkey over 3 years ago
    You have got the right DT bode plot.
    For time-averaged PAC, you have got a response looks like sinc function (green one, it looks right)
    For sampled PAC, you should get a replica response in every Fs frequecncy (blue one, it also looks right)
    The blue one seems not that accurate, if you change you frequncy display type, or try linear with smaller step, or logrithm with 100 points per decade, you will get a more accurate response: exact replica every fs and each has fs/2-symmetry .
    For CT circut, I think you could also get a sampled PAC: just place a vpulse without any connection,  then use vpulse's frequecy as pss-beat-frequency and use it's posedge as sampled event. (make sure your circuit is periodic or just simply set the input transient signal = zero).
  • bernd2700
    bernd2700 over 3 years ago in reply to SpiceMonkey
    Dear SpiceMonkey,
    Thank you for your reply!
    You write “For sampled PAC, you should get a replica response in every Fs frequecncy (blue one, it also looks right)”. Yes, you are exactly correct, I “SHOULD GET”, but I think I unfortunately “do NOT get” if I watch the blue curve. Why? Because a DT spectrum must be symmetrical around fs/2, and fs/2 in my case is 500 Hz. So I would have expected that the line is up at 0 dB again at fs = 1kHz in the Bode diagram, as it is also 0 dB for DC (here at e.g. 1 mHz since it’s a log plot). But it does NOT show 0 dB at fs = 1kHz. Instead, it goes further down with e.g. -20dB/dec, which, as a consequence, tells me, it is NOT the DT spectrum / response what I get but something else. Which simulator setup do I miss, or what I am doing wrong here? So, what to do, in order to obtain the Bode plot’s DT response, since Mr. Kundert perfectly has written in an article: “... you must understand upfront if you are interested in the CT or in the DT response of a system” => And yes, I am interested in the DT response and was thinking: This, I will get with the “PAC _sampled_” analysis at a specific (e.g. rising or falling) edge (every 1 ms), but as the Bode plot reveals, for me ( = not being symm. around fs/2) I still did NOT obtain the DT response.
    I even have 1000 points per decade, and from the below picture, you see, it is NOT symm. around fs/2 = 500 Hz, therefore your first sentence “You have got the right DT bode plot” confuses me.
    If you look at my schematic, it is exactly what I already did what you propose: I added a vpulse with 1kHz and used it for the PSS, see voltage “v1” and node “p1” there.
    Above Fig.: SpectreRF PAC sampled analysis, e.g. at rising edge (@ 500us): There is NO line going up to 0 dB again at fs=1kHz => No DT Bode plot!
    Thanks a lot so far and I am curious about your answer(s),
    bernd2700
  • Frank Wiedmann
    Frank Wiedmann over 3 years ago in reply to Frank Wiedmann
    bernd2700 said:
    “After the first sampler, the circuit can no longer distinguish between a frequency f and a frequency n*fs+f or n*fs-f”
    If I am correct, the reverse conclusion out of this sentence is: As soon as I use a sampler in the circuit, it automatically must follow a DT signal on its output.  –  However, this doesn’t seem to be the case if you watch my circuit at the very top at this post and follow the blue curve ( = node “Vo_sh1” , after the sampler): The spectrum is NOT being DT.
    I have understood:
    *) You basically say:      Install a sampler in the circuit and its output is DT.         <== This would be also logical to “my theory”!
    *) PAC sampled, however, says:      Although a sampler installed in the circuit, its output is still CT (blue curve).
    For me this is a contradiction. Where is the error??
    The first sampler does cause aliasing, but you will only see an effect of this if you have a frequency-dependent circuit after the first sampler, not if you sample its output directly.
    bernd2700 said:
    So, I would like to have a general valid statement between the relation of the normal PAC and sampled PAC.
    There is no such statement, because the relation depends on the shape of the output signal. For a piecewise constant signal, the results are related by the sinc function; for a sinusoidal signal, they are the same.
    bernd2700 said:
    “In order to be entirely precise, sampled PAC analysis does not generate a sampled output spectrum, but it samples the transfer function”
    Although I have found it to be for sure a very important info, I am also not completely sure about what you meant here exactly with “samples the tf.” How can something sample a tf?
    Ok, a better formulation would be: "The sampled PAC analysis samples the output signal and uses the result (consisting of Dirac impulses) to calculate the transfer function."
    bernd2700 said:
    “Wikipedia explains why going from a signal consisting of Dirac impulses to a piecewise constant signal in the time domain corresponds to a multiplication by the sinc function in the frequency domain."
    But I do not have a signal consisting of Dirac impulses. I have an analog sinusoid input source and on the output a ZOH. For me this Wikipedia page is not answering my specific question here, or I do not get the point all the time – could be!
    What we are comparing here is the result of a sampled PAC (Dirac impulses) and a normal PAC (piecewise constant signal).
    bernd2700 said:
    In the other forum topic (goto: “51410”), you write: “if you sample a signal in the time domain (by multiplying it with the sampling function), you need to convolute the spectra …” So yes, we sample in TD. But in your Matlab example you still do a multiplication in FD “... = pac_sampled.*sinc( ...” and the result seems to be correct.
    When you go from Dirac impulses to a piecewise constant signal, you convolute in the time domain (with the rect function), so you need to multiply in the frequency domain.
    bernd2700 said:
    Last: Can I force SpectreRF to produce a DT Bode diagram? (Independently of the schematics)
    Not if you have a CT circuit like a simple RC filter.
  • bernd2700
    bernd2700 over 3 years ago in reply to Frank Wiedmann
    Dear Frank,
    Many thanks for your detailed reply!
    You write: “The first sampler does cause aliasing, but you will only see an effect of this if you have a frequency-dependent circuit after the first sampler, not if you sample its output directly.”
    It seems to be again an important answer from you. Ok, clear is the first part: That it does aliasing, because it’s a sampler.
    Not clear:
    1. Which “effect” do I see? You probably mean the effect of getting a “DT” response instead of getting a “CT”?
    2. And why there is a difference between if I sample the output directly or if I have an additional frequency-dependent circuit AFTER the first sampler?? I tried to imagine this, but I couldn’t. Please, Frank, could you explain this in a bit more detail what is going on here?
    3. More a rhetorical question is: "What would happen if I have an additional circuit after the 1st sampler but not a frequency-dependent one, like a gain block (e.g. a resistor divider)?" Because I think, if once I fully have understood it, I can give the answer by myself what happens for any type of circuit installed after the first sampler.
    You write: “the relation” (between the normal PAC and PAC sampled) “depends on the shape of the output signal”.
    I had this fear, that this is the case. But this maybe explains why I’m having difficulties to find a general flow diagram in frequency-domain for the PAC analysis stuff. E.g. I therefore canNOT generally write “pac_normal=pac_sampled.*sinc(f*ts);”, because it seems circuit dependent if this equation holds true or not. That’s a pity, because I would have liked to write general valid equations for the relation. But you clearly write: “There is no such statement”.
    You write: “What we are comparing here is the result of a sampled PAC (Dirac impulses) and a normal PAC (piecewise constant signal).”
    So from this section, I understand:
    1. a) Sampled PAC = Dirac impulses
    2. b) Normal PAC = Piecewise constant signal
    What I’ve learned from you and from Wikipedia is: The procedure clearly is:
    ==> “In order to come from a) to b), install a ZOH in-between”!
    For me, from this section here, this clearly looks to be circuit INdependent, because to get from a) to b), one MUST install the ZOH, there is no other way to obtain a piecewise constant signal out of Dirac impulses, is there?
    As a consequence, it’s still a contradiction for me! : From this section it seems to be generally valid, from the very above section it depends on the circuit I use, if I do need a ZOH not to go from Sampled to Normal PAC. Fu**, I am again confused now about this.
    You write: “The sampled PAC analysis samples the output signal and uses the result (consisting of Dirac impulses) to calculate the transfer function.”
    Did you try to just express in other words, what we do anyway, or is there more to it which I maybe miss? :  Ok, the PAC samples the output, and then for the tf. calculation, it just does “(max-min)/2” (if the input is normalized to “1”), correct? Or do I miss something here for the “calculation of the tf.”? There is no additional tf. calculation inside the PAC, correct?
    And why: As soon as I take the regularly sampled values (at n*Ts), why then in Cadence PAC sampled the response is not automatically forced DT?
    Isn’t a DT spectrum just a consequence out of regularly sampled points in time? Obviously in Cadence PAC sampled: No (Otherwise I couldn’t get out a CT response of my normal RC-LPF circuit.)
    But, if in contrast, I do a DFT (in Matlab e.g.), the spectrum IS automatically DT ( = being symm. around fs/2), and I guess, it’s not the “fft” process itself which makes it DT, but it’s the regularly sampling process which is responsible for the DT spectrum. So ???
    Ok, this point is solved now: I cannot _schematic-independently_ FORCE a DT response from the Spectre PAC. Up to now, there is no such selectable option in its menu implemented to do so. => Thanks for stating this very clearly!! (Would be nice for the future to see such a thing there.)
    Again, “1000 * Thank you”, Frank to bring some clarity on this, as it seems for me that no book in this world is able to write this nicely and in simple sentences, so that everyone can understand.
    bernd2700
  • Frank Wiedmann
    Frank Wiedmann over 3 years ago in reply to bernd2700
    How do you want to see a repeating gain pattern as the result of aliasing if your DT circuit has a gain that is constant over frequency?
    There is an important difference between the spectrum of a sampled signal and the result of a sampled PAC analysis. For a sampled signal, due to aliasing you generally don't know the original frequency of the signal (unless its bandwidth was limited before the sampler). Due to this, all possible frequencies are often shown in the spectrum, which automatically leads to the well-known repeating and symmetrical spectrum of a sampled signal.
    In sampled PAC analysis, however, the frequency of the input signal is known and is used as the x-axis for plotting the result. As a consequence, you will only see a repeating and symmetrical pattern if it is caused by the circuit itself, for example by a frequency-dependent circuit after aliasing by a sampler.
    The normal PAC of course uses whatever shape the output signal actually has. For many DT circuits (like the example used here), this is a piecewise constant signal, so you get the sinc relation. For a CT circuit like a simple RC filter, with a sinusoidal input you will of course also get a sinusoidal output, which is why normal PAC, sampled PAC and AC analysis will all give the same result in this case.
    A CT circuit like a simple RC filter does not produce a DT response, so I doubt that you will ever see this.
  • bernd2700
    Dear Frank,
    Thank you VERY much for your answer containing some other important info and clarifications!!! Now, just please gimme some time again. I do and try now a lot of different things, and I need time to digest all this in combination with your answers.  As said, I do not like to "only ask a question" to the audience here, just in order to create work on you. So the better choice is: I will come back with well prepaired questions (if not everything is solved in the meantime, hahaha) but it needs a while...
    Again, many thanks so far,
    bernd2700
  • bernd2700
    bernd2700 over 3 years ago in reply to bernd2700
    Dear Frank,
    I made an additional graphical representation of my subsequent verbal description. It’s maybe easier to follow then.
    From below figure, you can see: I simulated 2 circuits as Device Under Test (DUT): A) Ken Kundert’s “Ideal S&H”, and B) Your SC-Filter (with modified frequencies, Period = 1ms instead).
    For both, I did the Cadence internal PAC sampled as well as an own generated AC analysis & compared the results of all.
    Explanation of my own AC analysis: It works as follows: At the input of the DUT, I fed a Multi-Tone (MT) stimulus, that are hundreds of automatically stacked sinusoid sources with each 1V amplitude and frequencies reaching from ca. 10mHz until 5 kHz (log. spaced). With the exported transient data over Cadence’s calculator command “sample”, I then do a DFT from both, the input node “u”, as well as from the concerned output nodes. Then I do a division of the 2 DFT results and a Bode diagram of it. (It was some work to get everything done correctly.)
        (click to enlarge)
    For both cases A) and B), I honestly would have expected a DT Bode diagram = a repeating pattern around the circuit’s sampling frequencies of 1 kHz, as there is both existent, namely *) no band-limitation before the first sampler (thus aliasing) and also *) equidistant sampling “n*Ts”.
    For case A), you see: Although Aliasing + Equidistant sampled („n*Ts“) signal => I do NOT get a DT Bode plot.
    I was thinking: I always automatically get a DT response ( = a repeating gain pattern around the sampling freq.) as soon as I start doing equidistant sampling in time “n*Ts”, and moreover, regardless of if I have additional aliasing caused by anything or not. Both is obviously wrong: Neither do I get a DT Bode plot when just doing equidistant sampling “n*Ts”, nor when doing equidistant sampling plus aliased signal.
    How then will I obtain a DT response? => You will say: If the circuit itself doesn’t give it, then I won’t get it. Which sounds true to me especially now after those experiments, and as you have written, too: “... you will only see a repeating and symmetrical pattern if it is caused by the circuit itself ...”.
    But why the hell then Mr. Kundert has written in his (already above cited) article: “You must understand up front the difference between the continuous-time and discrete time behavior of your circuit, and you must decide which behavior you are interested in.”. But it now seems, if the circuit is fixed, I do not have anymore the freedom to decide, if I want to see the circuit’s CT or DT behaviour, do I? It seems now, that either the circuit gives a DT Bode plot or not. Thus, for me, your statement ( = you will only get DT if caused by the circuit, no “user” decision) is then in contradiction to Ken Kundert’s statement ( = think and decide already upfront if you want to see the CT or DT response of a circuit). I am sure, you both are somehow correct, but:
    => Where is my thinking error which causes this contradiction?
    You wrote: “you will only see a repeating and symmetrical pattern if it is caused by the circuit itself, for example by a frequency-dependent circuit after aliasing by a sampler”.
    Perhaps this is the key message and I read 100 times this. If I only could understand it! The only thing I can think of how to do this, is to add some transfer-function in “z” after the sampler, because I am already now in digital domain, because I have values which are valid only at n*Ts. But then, this DT behaviour is not caused by the circuit itself but by this another added tf. . For instance: Of course, if I add after the first sampler a discrete integrator “1/(1-z^-1)”, I surely get a DT answer. Acc. to you, I really would not get it, if I just add a non freq. dep. tf. (in magnitude you mean, I guess), such as a plain delay "z^-1", correct? Or possibly I think in the wrong direction...
    And: Both A) and B) are sample and hold circuits with each 1kHz (or 1ms sampling period) and for both the input stimuli are up to at least 5 kHz, so both should produce aliasing.
    => Why for case A) I obviously get a CT Bode plot, whereas for B) I get a DT Bode plot (Of course, I also remember what you have written: The cyan curve here looks “very similar to the result of the time-continuous filter, but it is really the red curve multiplied by the sinc function due to the zero-order hold at the output”. => Is the cyan curve here now a CT or a DT response? At least, the pattern is not repeating.
    Thus, is my following statement true or false:
    *) Repeating pattern => DT response
    *) No repeating pattern => CT response
    In my head (until now) the following statement does NOT exist:
    *) No repeating pattern => Nevertheless possibly a DT response
    And: E.g. for case B) : What / where is the difference between: [“PAC sample: n*Ts” (red, green curve)] and [“Calculator sample: n*TS” with DFT (blue)] ? If I manually sample and do DFTs, I get the blue curve, if do the PAC sampled, I get the red or green curve. Both do "n*Ts" sampling, but the results are very different.
    Thanks a lot for your help in advance & best regards,
    bernd2700
  • Frank Wiedmann
    If by "DT response" you mean the result of a sampled PAC analysis, it is clearly false (as you have shown with your own experiments). Also, your transient analysis does not really represent what a sampled PAC analysis does, because you sample a piecewise constant signal with a period of 1 ms every 0.1 ms, getting 10 equal samples in a row each time. I am not going to try and interpret the results of this strange setup.
    You really need to distinguish between the spectrum of a sampled signal and the transfer function resulting from a sampled PAC analyisis:
    The sampled PAC analysis only looks at the output at the input frequency (because I chose maxsideband=0 as a parameter) and only plots it at this frequency. The fact that the sampled output signal could also be interpreted as coming from different (aliased) frequencies is not taken into account here. If you also want to see the result at the aliased frequencies, you can set maxsideband to a larger value, which will give you copies of the result shifted by multiples of the pss fundamental frequency.
    By the way, the normal PAC analysis with maxsideband=0 like in my example also only looks at the output signal at the input frequency. For a piecewise constant signal, there will be additional frequency components in the spectrum, possibly with much larger amplitudes.
    I believe that he was talking about the difference between a track-and-hold and a sample-and-hold. Sampled PAC analysis with Dirac impulses did not exist back then. At that time, I was emulating it with sampled PNOISE analysis and separate noise sources for every Nyquist band.
    Correct. This is also the reason why you get a straight line at 0 dB if you do a sampled PAC analysis at the output of an ideal S&H (and the result of the normal PAC analysis is simply the sinc function in this case). By the way, you will also get a repeating and symmetrical result of the sampled PAC analysis if you add an RC filter after the ideal S&H.
    It is the result of a normal PAC analysis of a switched-capacitor (and thus sampling) lowpass filter with a piecewise constant output signal, looking only at the frequency component at the input frequency.
  • bernd2700
    Dear Frank,
    Just very quickly to the point difference "Spectrum of sampled signal" and "PAC sampled":
    You wrote: “Ok, a better formulation would be: "The sampled PAC analysis samples the output signal and uses the result (consisting of Dirac impulses) to calculate the transfer function." ” , and “In sampled PAC analysis, however, the frequency of the input signal is known and is used as the x-axis for plotting the result ”
    In my opinion, with my “MT AC analysis” I do like Cadence “PAC sampled” does, therefore I did all this experiments (and so, the necessary equations I can type and port to any mathematical program, whereas e.g. in Matlab I cannot say: “Please perform a ‘PAC sampled’ analysis.”):
    *) “PAC sampled” samples the output signal. => Also my “MT AC analysis” samples the output signal. (Over Cadence’s calculator command “sample”).
    *) “PAC sampled” calculates the tf. => Also my “MT AC analysis” calculates the tf. (by dividing the 2 DFTs “output/input”). (And I tested my script to be sure that it works properly!)
    *) “PAC sampled” knows its input frequency and uses it as x-axis for plotting. => Also my “MT AC analysis” knows the input frequency and uses it as x-axis for the Bode plot (as of course I also have plotted the values ONLY at those input frequencies of the MT stimulus, not at all the others as well).
    *) “PAC sampled” even looks until 100 kHz which is far above the circuit’s fs = 1kHz. => Also my “MT AC analysis” looks far above 1 kHz, namely at least until 5 kHz (the transient analysis for this took already approx. 1 hour), to also be able to “see” what happens above 500 Hz ( = fs/2 of the circuits), so which spectrum I will obtain, a repeating one or not. (I do not have a clue, why you call this “strange setup”, because I think, this is also what the “PAC sampled” does, just that this even goes further until 100 kHz in this case.)
    => Where is the difference between “PAC sampled” and my “MT AC analysis” then?? (Apart from “PAC sampled” is much faster and only needs approx. 1 minute).
    Thx,
    bernd2700
  • Frank Wiedmann
    The problem I see with your approach is that you are trying to simulate all input frequencies at once and are going beyond the Nyquist frequency of the circuit at the same time. A sine at the input of these circuits will not just cause a frequency component at the input frequency in the output signal, but also at other frequencies (where you also might have an input signal). Have you already looked at the output spectrum when you just have a single frequency at the input?
    But the reason why you are not seeing a repetition in the result for circuit B) is probably that you are sampling the piecewise constant output signal, which causes a multiplication by the sinc function and gives you the cyan curve as a result. You could try to model Dirac sampling by only keeping every 10th sample and setting the other 9 identical samples to zero. Maybe this will give you the result you are looking for.
  • bernd2700
    Dear Frank,
    Aaahhhhhhhh, Yeeeesssssssss, clear!! How easy! As you proposed, I will check with 1 freq. at a time only.
    (I would like to also do this freq. sweep automatically, but for this, I would also need then hundreds of transient sims in Cadence (1 takes currently ca. 1 hour) + DFTs + manually export the data hundreds of times + combine all this into 1 plot. Is there maybe another way what I do not think of in this moment?)
    Also one other thing is now clear (For the other readers, here clearly stated): By sampling with 10 kHz an already sampled signal with 1 kHz, I get, as Frank correctly said, 10 times the same value, before it changes to the next one. That can be called a “Repeater”. And a “repeater” is mathematically identical, as far as I know, with zero stuffing ( = as you propose, set the other 9 identical values to 0) PLUS a comb filter of first order, so “(1+z^-1+z^-2 ... z^-9)^1”, which causes this sinc. behaviour. I will do this (need a bit of time to do properly).
    So I obviously INADVERTEDLY created an additional, 2nd sinc. filter by doing the repeater (the first one is already inside the “DUT”), killing my expected repeating spectrum at 1 kHz at the output. Things are getting much clearer now!
    However, what I also need to think about in more detail, is, when now looking quickly at once glance to the following: With the 2 times in series sinc. filter for e.g. (also?) circuit A), I would expect either:
    *) Because of my 2nd inadvertedly indroduced sinc filter by doing repeating upsampling, shouldn’t for case A) the blue curve be attenuated more than the green one from the PAC (see zoomed fig. below), or:
    *) The result from the Cadence “PAC sampled time averaged” (green) should exactly match the blue, if e.g. the “PAC sampled time average” does the same effect, so to also introduce a sinc (I don’t know what does “time average” exactly)
    Or maybe this ca. 3 dB difference (from -19.82 dB to -22.98) already close to "DFT fs/2" comes from another effect?
                           (Case A, zoomed)
    And then, why I see a constant line with ca. 0 dB for “PAC sampled edge ris. or fal.” (not shown in this graph)? Because 1x sinc. filter should still be present from the DUT, only the 2nd one from upsampling is gone when performing the internal Cadence “PAC sampled ris./fal. edge”, because this is doing, I learned from you “ideal Dirac sampling” which doesn't show sinc behaviour. You wrote “This is also the reason why you get a straight line at 0 dB if you do a sampled PAC analysis at the output of an ideal S&H (and the result of the normal PAC analysis is simply the sinc function in this case)”. But I solely did a “PAC sampled”, not a “normal PAC”, and I still can chose to either get a “sinc.” shape (with option “time averaged” or approx. a straight line (with option rising or falling edge). But BOTH are “PAC sampled” analysis (only sub-options to select). Or, as my question from previous, I may repeat: Is statement: “PAC sampled, time avg.” = “normal PAC”, true or false? So ???
    But one step after the other ...
    Anyway, 1000 thanks - Very nice, Frank, that you bring it to the point!!
    bernd2700
  • Frank Wiedmann
    There will be no problem with your approach if all input sources are in the same Nyquist zone, so you don't need one simulation per input frequency, just one per Nyquist zone. And of course this method will only work for a linear circuit.
    Without analyzing this in further detail, I would guess that it is the same effect that you see at fs/2 in this plot:
    Here are the simulation results:
    If you perform Dirac sampling at the output of an ideal S&H with the same sampling frequency, you will get exactly the same samples as if you perform Dirac sampling at the input of the ideal S&H.
    True, as far as I know (Andrew, please correct me if I'm wrong).
  • Frank Wiedmann
  • bernd2700
    Dear Frank ( & others),
    As said, thank you for pointing this out with the zero-stuffing. For all: Here is the proof, at least now for case B) : In the graphs below, the blue curve is the sampled data (with Cadence’s calculator “sample” command) with period = 100us (and thus the same values are repeated 10 times, because the period of the circuit’s switches is 1ms), and we do NOT see a DT spectrum. That is, because it was filtered away by the inherent comb filter which exists when doing repeating. If I do zero-stuffing (so as Frank proposed: set the other 9 values to 0) and thus only do “Ideal Dirac sampling”, I really get my expected DT response (red curve = symm. around the circuit’s fs/2 = 500 Hz, repeating pattern with 1 kHz)! As theory predicted, by subsequent comb-filtering the red curve, I finally get the magenta curve, which is again identical to the blue, q.e.d. .
    And if we compare this to the internal Cadence PAC (green and cyan), everything now fits nicely!
    It was a lot of work to come to this point, but everything definitely was worth it to do, and so: “Thanks Frank!” Without your help, I would not have been able to do all this completely alone by myself.
    Side info: You have to be careful with the things: DFT, zero-stuffing, comb-filtering, shifting, to do all this very properly (otherwise you easily can get sinc. behaviour at wrong frequencies, etc.). But also here is the advantage of doing this completely by oneself: You understand what's going on behind the scenes, because you know exactly what you did. (I cannot show all the details here, since it would explode the frame of this post, but at least this hint from my side.)
    I will now apply the same procedure for the other cases (for case A) and for the purely analog RC-LPF) and check, if finally everything fits to my expectation.
    Many nice greetings so far,
    Bernd2700
  • bernd2700
    As said, I did now the same game for test-case “A)”. And I like it! : My manually applied procedure also here is fitting pretty well to the internal Cadence PAC, as you can see below: The blue curve is the sampled data at fs_DFT = 10kHz with repeated 10x values, because the circuit’s “fs_S&H = 1kHz. The red curve is the zero-stuffed out of the blue, so “Ideal Dirac sampling” done and thus fits to the internal “Cadence PAC sampled: ris. or fal. edge”. The cyan is the comb-filtered red and thus perfectly fits to the blue again (as previously explained). And I think, the red line can be called a DT response (everywhere 0dB is thus also symm. around fs/2!)
    What fits perfectly at lower frequencies and deviates more and more apart as frequency is increasing, is the (blue or cyan) compared to the green PAC sampled, time averaged. Around 4.5 kHz, I get a difference of 3 dB (ca. -20 dB for the blue and cyan, and -23 dB for the green). But as you said, Frank, it might be the same what you were  showing, when going close to DFT fs/2 = 5 kHz, and things would maybe resolve, if I do the game with fs_DFT sampling up to 100 kHz and thus getting the spectrum up to 50 kHz, instead of only up to 5 kHz. (Then, the transient sim. would be probably very long, so I did not do it. However what I quickly did, is to do a PAC only until 10 kHz (thus showing a spectrum until 5 kHz), but it is exactly the green curve, just plotted until 5 kHz.)
                                                          (click to enlarge)
    For my curiosity, I now input instead of a MT, only exactly 1 tone, namely with ca. 4559 Hz, and the result is:
    Here, everything sounds logical: I get alias components at fs – fin = 5 kHz – ca. 4559 Hz = ca. 441 Hz, and all its replica. As it should be now, exactly as the Cadence PAC does, only 1 input tone, I was expecting to see at 4559 Hz also this -23 dB. But instead, I see -20.07 dB.
    I also now tried to look what the PAC does. As you proposed, I take the output from the transient analysis with only that input tone of ca. 4559 Hz (in steady state condition, so close at the end of the sim. at 104.8 s) and again do “(max-min)/2” from the values. As we also see at one glance, I roughly get this 0 dB (exactly being: 20*log10(1.9556/2) = -0.19 dB), as the PAC sampled: ris. / fal. edge delivers (the straight line at 0 dB). But how does the PAC sampled, option “time averaged” work here? What to measure to get the -23 dB instead? For sure, there is also a way, but how?
    bernd2700
  • Frank Wiedmann
    I don't think that you actually need to run the simulation. Just modify your sampled signal so that you now have 100 identical samples instead of 10 indentical samples in a row.
    This is just the nomal PAC analysis without any sampling, so you simply need to run an FFT on the output signal in order to get the result in the frequency domain.
  • bernd2700
    Dear Frank,
    In principle, a good idea to do every 100th sample, but I think it will not work, as I really do not produce input tones above 5 kHz, and so my AC analysis will divide then just mathematical “noise”. Moreover, I think if I set just the parameter “fs = 100 kHz”, all the frequency vectors with the real injected sinusoids will get misaligned then (or if I increase all by factor 10, everything is just shifted by factor 10, or… ).
    What is much more important, is:
    The following procedure EVERYTIME perfectly (almost) fits to the Cadence PAC sampled, time averaged analysis: Generate multi-sinusoids, then run a tran. analysis of the DUT, then sample the transient data (calc. command “sample”), then doing the DFTs and divide output/input. So this is my blue curve. And, I think I can summarize and state with confidence now:
         [ My manual MT AC analysis over the 2 DFTs ( = blue curve) ] matches [ PAC sampled, time averaged ]
    However, what did only work out for test-case “A)” and B), is: By further manually doing zero-stuffing out of the blue curve, and so doing “Ideal Dirac sampling”, this (my red curves) then fits to the “Cadence PAC sampled, e.g. rising edge”, because:
    I now tried to apply the same procedure - as completely successfully done with test-case “A)” and B) - also now for the purely analog RC-LPF circuit, and it does not fit to the PAC sampled, e.g. rising edge. The results can be seen in below graph:
    My blue curve again fits perfectly to the Cadence PAC sampled (green), e.g. time-averaged option. But this time, all options of PAC sampled produce the very same result: “rising edge”, “falling edge”, “time averaged”.
    And so, by blindly applying the same procedure again as done with the previous test cases A and B, (Sampling, DFTs, then zero-stuffing, then comb filtering), this time I get garbage (red and cyan), because the circuit this time does NOT have an (inherent) ZOH at its output where the data is repeated 10 times the same value.
    My problem now is: I of course cannot include “switch - case” statements in my analysis, depending on a circuit! A la: If there is a ZOH-like-thing in the circuit, then the red line will fit to PAC sampled rising edge; if not, the blue curve already will fit to PAC sampled rising edge. The analysis itself is stupid and cannot know the circuit (and the circuit’s fs), and thus, the procedure has to work for EVERY circuit analyzed with it, as the Cadence PAC does!
    => So what can I do about that I not only get a more or less perfect matching to the “PAC sampled, time avg. option” with my own analysis, but also for the “PAC sampled, ris. or fal. edge option”, regardless of the DUT I have?
    Pleeeeeeaaase, give me an advice.
    Thanks a lot,
    bernd2700
  • bernd2700
    Sorry, guys, this phenomenon, I just saw, has nothing to do with the PAC sampled, it also occurs when I stay purely in Matlab.
    I did the following test: I got the idea and simulated the same pure analog RC-LPF, but now completely inside Matlab (over Matlab's "lsim"), and subsequently applied the very same procedure (just with other fs and number of samples) as always done now, and I get below result:
    I expect that the cyan curve will be the same as the blue, but it isn’t!
    So please, for the moment being, forget my question of the previous post (that applying the same procedure does not fit for Cadence PAC sampled, ris. or fal. edge).
    I quickly wanted to update you now with this info.
    So I just have to debug it what’s going on here ...
    Sorry for having asked too early, before I did this test case over pure Matlab, but my idea came just now.
    bernd2700
  • bernd2700
    Case “Purely analog RC-LPF”: Matlab internal comparison
    First of all, case “Pure analog RC-LPF” from just above post: I did not find any errors in my scripts, so I think when doing zero stuffing, I just lose information (because concerned samples then replaced with the value “0”), and it can be proven, that the less I do zero-stuffing, the more the cyan or red line resembles the orig. blue line (graphs not shown to not overload this post).
    Case A) = “Ideal S&H”: Comparison with extended frequency range
    The sim. results are here from my MT DFT analysis, now in extended frequency range. Originally, I sampled up to 5kHz, and now until up to 50 kHz. As expected, the results do fit perfectly also until approx. a factor 10 more in frequency, as we can see from below graphs: On the left, there is a repeated 1:1 copy from the old post just for remembering, on the right, also including the new yellow extended freq. analysis result. We see, the blue orig. 3 dB deviation at 4.5 kHz to the green Cadence PAC, time avg. is completely gone now. Now, the yellow curve fits perfectly to the green until approx. 10 kHz.
        Case A) “Ideal S&H”:
        Left figure: Repeated 1:1 copy from prev. post   ;         Right fig.: Now + yellow curve with extended MT freq. range.
    Case “Purely analog RC-LPF”: Comparison Cadence PAC <=> My MT AC analysis
    I extended the frequency range for my MT analysis also for this case now up to 50 kHz.
    As we see, the results from my MT AC analysis below (blue), and from the Cadence PAC sampled, time avg. (also below, also blue line) PERFECTLY match!
    With my analysis’ frequency range increase from 5kHz to 50 kHz, you can see from the result below, the cyan line perfectly fits the blue line now also up to some kHz, as expected.
    Although I now additionally also used a 2nd period only out of the base frequency of some mHz and thus have steady-state condition for my DFT, we still must clearly say from approx. 5 kHz up to DFT fs/2 = 50 kHz, the cyan line does not fit the blue line. And my red line does not fit the PAC sampled, rising edge (red and orange).
    For the Cadence PAC sampled, rising edge, this performs somehow better when looking to the higher frequencies, say from 10 kHz onwards up to its fs/2: The internal deviation from the PAC sampled, ris. edge (red and orange) is not so big to its time averaged option (blue and black), as my internal deviation over my MT AC analysis between red and blue - this is bigger.
    We can compare the both red curves, one from my above MT AC analysis and one from the Cadence PAC sampled rising edge, and they should approx. yield the same result. But they do not.
    Maybe the Cadence PAC does some internal additional calibration before and / or does higher oversampling even though not requested (I have reduced, as you see, also the maxacfreq. for this purpose. But also for case A) the 2 time avg. results are really look-alike up to even fs/2 ; graph not shown here).
    => I don’t know, but maybe you, Frank, why the internal Cadence PAC sampled, ris. edge (red) is closer to its time-avg. option (black), than my MT AC analysis “Ideal Dirac sampled” (red) to my “normal DFT” (blue)? So, in other words: Why Cadence PAC sampled, rising edge seems to do not lose so much information in doing also “Ideal Dirac” sampling as mine? Which factor Cadence PAC sampled does? I here used a factor of 10 (so 1x the value, 9x zero).
    Thanks a lot,
    bernd2700
  • Frank Wiedmann
    The sampled analyses of Spectre always sample exactly once per period (as given by the PSS fundamental frequency). You only needed to do the "zero-stuffing" because in your transient analysis, you were sampling the output with a higher frequency than the frequency of the sample-and-hold (which is not possible in sampled PAC). When you do the "zero-stuffing" on the time-continuous circuit, you effectively (down-)sample the output at a lower frequency, resulting in aliasing effects in your red curve.
  • bernd2700
    Dear Frank,
    Many thanks for your answer! Unhappily, I did not understand all parts of it. Starting with the unclear parts. I always like examples.
    So, watching my simulated circuit below again: For a test I have changed now the sampling frequency of the “Ideal S&H” from orig. 1 kHz to now 10 kHz (period=100u) to not be the same as the clock source “V0” (per=1m). This still defines my fundamental beat frequency unchanged with 1 kHz in the PSS.
    You wrote: “you were sampling the output with a higher frequency than the frequency of the sample-and-hold (which is not possible in sampled PAC).”
    Yes, with my MT AC analysis, I sampled the output with a higher freq., namely with 100 kHz. But also, the Cadence PAC sampled, I tell: “Please plot me the freq. response until 100 kHz”. And so, as far as I understood correctly, when reaching this frequency, 1 sinusoid only with 100 kHz is injected into the DUT (with 1 V, I have specified). As a consequence, the PAC must sample the output with at least 200 kHz to properly fulfill Shannon (Nyquist). And so: [Output sample freq. with 200 kHz with sampled PAC] >> [Freq. of “Ideal S&H” with 10 kHz]. This is possible. But possibly, you were meaning something else, but what??
    You write: “The sampled analyses of Spectre always sample exactly once per period (as given by the PSS fundamental frequency).”
    So again my example: If I want to see the freq. response at, say, 100 kHz, the “PAC sampled” must sample with >= 200 kHz. If this is, as you write “once per period”, then this period is 5us. But the PSS fundamental freq. is given with period 1ms. So it is 200 times per period. So for me, it is either not once per period or not given by the PSS fundamental period. So also here, sorry, I have no clue, what you mean. For me, the PSS is there to find a large-signal valid operating point of the circuit.
    You write: “When you do the "zero-stuffing" on the time-continuous circuit, you effectively (down-)sample the output at a lower frequency, resulting in aliasing effects in your red curve.”
    Ok, yes, this part is clear, because I did not allow even a still higher sampling frequency for my RC-LPF DFT result. I somehow wanted to compare my MT AC analysis to PAC sampled: And if I tell the PAC (or PSS in that case) “maxacfreq. = 100 kHz”, then I expected also comparable results. Indeed, we see, in repeated below graphs, that also the red PAC sampled curve with ”PSSmaxacfreq=100k” is indeed “noisy”, especially above 20 kHz, and the spikes of the red curve deviate to the blue line by also really a lot of dB, but in-between, the red curve reaches the blue again, and so I feel, the PAC sampled performs still “better” than my MT AC analysis, where between the peaks, my red curve does not reach the blue curve again (see yellow circles).
           Left: Cadence PAC sampled                          Right:      My MT AC analysis
           Case “Purely analog RC-LPF”, output node "Vo":
    Explanation for all the other readers (which seem to be quite a lot for this special topic, as I saw now with 2330 views, wow!):
    I have chosen “fs_DFT = 100kHz” (as said to be comparable to Cadence PAC sampled with maxacfreq.=100k), so my samples are e.g. [y1 y2 y3 ...] for the CT “RC-LPF” circuit. As you have proposed, Frank (but for case B) ), I do zero-stuffing also here with the same procedure [ y1 zeros y11 zeros y21 zeros ... ], so I throw away the samples y2 until y10 and so on. This means from signal-processing point of view, I did a “brute-force” decimation (by factor 10), I mean, without an additional anti-aliasing LPF, therefore Frank has written “... resulting in aliasing effects in your red curve”.
    So I will change now my procedure for the zero-stuffing method and will try in the following: [ y1 zeros y2 zeros y3 zeros ... ]. But this means, I have to effectively increase the sample rate now to fs_DFT = 1MHz (if I keep factor 10). And I will check, if I will obtain a DT for cases A) and B) and a CT response for the case “purely analog RC-LPF”.
    Short Summary about CT and DT response of a circuit:
    Because for cases A) and B), it’s the circuit which delivers more times the same value and in the case “RC-LPF” not. That’s why you, Frank, have written “If the circuit isn’t DT, you won’t get a DT response”. Now you made it clear to me, Frank (1000 Thanks!!!), but originally, it completely confused me from Ken Kundert’s statement: “You must decide upfront if you are interested in the CT or DT behavior of a circuit”. And so, I thought then, I can freely chose, which is not true. Ken Kundert means: If you have any purely CT circuit (e.g. this RC-LPF) and want to see its DT response (because e.g. it gets sampled later by a customer, so by a subsequent, additional CIRCUIT), you have to do steps if you also want to see what will this DT behavior be in the end (so you have to modify your CIRCUIT, e.g. install an additional “Ideal S&H” block). But in any case, you have to change your circuit, to see a DT for a purely CT DUT, like the RC-LPF. If you only change your analysis type (e.g. from “PAC sampled, option time averaged” to “PAC sampled, option rising edge”) for a purely CT DUT, you should see every time the same Bode plot, because a CT circuit does not have a DT answer. Correct, Frank?
    And this I will check if it is true not only for the Cadence PAC for all types of CT and DT DUTs, but also over my MT AC analysis procedure, now with “real” zero-stuffing (up-sampling) (but it will take some time)...
    Many thanks and nice greetings,
    bernd2700
  • Frank Wiedmann
    No, sampled PAC always samples with the PSS fundamental frequency. Of course it is possible to sample with a frequency that does not fulfill Shannon (Nyquist), you just have to deal with aliasing in this case. There are always many ways to interpret a sampled signal; sometimes knowledge about the frequency of the input signal helps with the correct interpretation. I already told you earlier:
    Setting maxacfreq too low will simply give you an inaccurate PAC result. The maxacfreq parameter of the PSS analysis limits the maximum timestep, so that high frequencies in the following small-signal analyses (PAC, PXF, etc.) can be represented with the required accuracy.
    I am not sure if it is very useful to invest a lot of effort into these "zero-stuffing" experiments. As I told you:
  • bernd2700
    Dear Frank,
    Yes, obviously I have a lack of understanding the PAC, and as a consequence, you unfortunately have to tell me: “I already have written you this and that”. But, believe me, it is NOT because I haven’t read all your messages carefully!
    So, I dare to summarize what you have said so far in my own words now, how I can imagine the PAC sampled is working. Please have a look:
    If I want to know what is the output amplitude at e.g. 4559 Hz for testcase A) ( = the circuit with the “Ideal S&H” only), I simply inject a sinusoid of only this frequency, run a transient analysis (with setting “maxstep” equal “1/maxacfreq”) until to be in steady-state condition. Then basically should I have the same accuracy as the PAC receives, correct? Subsequently, over the Cadence calculator’s function “sample”, I sample the output with my PSS fundamental frequency with 1kHz e.g. on every rising edge of the PSS clock source “V0”, and then measure the amplitude result by doing “(max-min)/2”. Correct? Then, I think, I have fulfilled your statements: I sample only once per fundamental PSS period, just at the right edge (to also have the phase correct), and I will get aliased components as well.
    ==> What is NOT clear to me, is the following: This “(max-min)/2” takes place in Time-Domain (TD). But you also write “The sampled PAC analysis only looks at the output at the input frequency”. So how the PAC can distinguish this, if something comes from an aliased frequency or not, if the operation is done in TD??
    And obviously, I got the results of -0.19 dB (so the straight 0 dB line) by doing “(max-min)/2” for the “PAC sampled, rising EDGE”, to be more precisely.
    ==> How can I imagine then / what does PAC internally do, in order to get from this “edge” to the “time averaged” option? I do not have to run it again, but only select this option of the already calculated results.
    Why I am asking this? Because without having understood how the PAC works, I think, it will be hard to find a valid procedure, that will then produce the same (or at least similar + understood limitations) results as the PAC itself. At the end, I want to tell my AC analysis over MT: “Please give me the equivalent result of PAC sampled rising edge” or “now please for time averaged”. Of course, for every DUT, exactly the same procedure shall hold true (Not: For circuit A do zero-stuffing, for circuit B another thing to get the same results as PAC option X). I have the feeling that I am near, but not still there: I think, I could reproduce all the PAC results of all options ("edge", "time avg.") of all the 3 test-circuits (DUTs), but I had to apply different procedures (1x DFT + zero-stuffing, and 1x DFT without it, to be equivalent to the “PAC sampled rising edge”, for instance).
    Many thanks,
    bernd2700
