  3. Running SigXplorer in Batch Mode
  • Replies 11
  • Subscribers 163
  • Views 19725
archive over 19 years ago
I'm looking for information (links, documents, advices, etc.) on how to run a SigXplorer design in batch mode.
While it's easy to find in the tool's course book the tlsim batch mode documentation (Appendix A), I'm still missing a full flow - for example how to obtain from the SigXplorer design (.top file) the spice files (main/stimulus/comps/interconn.spc) and other required inputs for the tlsim run.
Marcelo.
Originally posted in cdnusers.org by marcelor
    "..which section of the signal contains the changing fields.."
    The signal is composed of fundamental and harmonics of high frequencies
    Yet, It is the edges that indicate the presence of several high frequency components, which
    trigger varying field effects, and increasing electromoagnetic force that will
    impact the line elements
    Originally posted in cdnusers.org by elie
