  3. The default location of orCAD Capture library Pin Number...
  • Views 13100
The default location of orCAD Capture library Pin Number is incorrect
JON123
JON123 over 4 years ago
The default position of the pin number is incorrect.
  • steve
    steve over 4 years ago
    Check which version you are using from the Start Page or Help - About. If memory serves me correctly this used to be an issue but has been fixed in a hotfix. Get the latest version from either Download Manager or http://support.cadence.com
  • JON123
    JON123 over 4 years ago in reply to steve
    Has been updated to 023; this problem only occurs when the lib is created; it is normal in the schematic. It should be a bug.
