  2. Logic Design
  3. read from text file with two values and represent that as...
  • Subscribers 63
  • Views 8584
read from text file with two values and represent that as voltage signals on two different port a and b
Hagar Hendy
Hagar Hendy over 3 years ago
i want to read from text file two values  on two ports , i wrote  that  code, and i have that error that shown in the image below . and also the data in text file is shown as screenshot
module read_file (a,b);
electrical a,b;
integer in_file_0,data_value, valid, count0,int_value;
analog begin
@(initial_step) begin
in_file_0 = $fopen("/home/hh1667/ee610/my_library/read_file/data2.txt","r");
valid = $fscanf (in_file_0, "%b,%b" ,int_value,count0);
end
V(a) <+ int_value;
V(b) <+ count0;
end
endmodule
    ShawnLogan over 3 years ago
    Dear Hagar Hendy,
    As a start, first change your input data file "data2.txt"
    1
    1
    to
    1,1
    As the error clearly indicates, the format specification in your $fscanf statement is not consistent with the data format in your file.
    Shawn
