  2. Logic Design
  3. Unable to open 64bit version of simvison
  • Subscribers 62
  • Views 8637
sthoppa
sthoppa over 2 years ago
I am not able to open 64bit version of simvision using the following :
simvision -64 -wav "path to wav"
This throws the error "  /lib64/libc.so.6: version `GLIBC_2.14' not found"
I am only able to open it without the -64 option.
As a result I am not able to use the source browser feature since the simulation was run in 64 bit mode.
Need suggestion on how to resolve this. Thanks.
  • sthoppa
    I was able to resolve the issue by adding the glibc-2.14/build path to my library path.
    I don't see issues anymore, source browser works as expected in 64b mode.
