  2. Allegro X APD
  3. Relative delay analysis is impacted by pbar
  • Subscribers 67
  • Views 7344
JS532
JS532 over 2 years ago
Does anyone know how to not include a pbar in a constraint manager analysis? I have some relative delay constraints applied on a group of differential nets. When I analyze the design these all show an error. If I delete the plating bar from the design they are all passing. The plating bar gets generated on the Substrate Geometry / Plating_Bar class. I understand that I could just delete the plating bar to verify the constraint but the issue is when I archive this design I would like it to be clean meaning it is in the final state for manufacturing AND passing all constraints according to design reviews.
Anyone have an idea?
Thank you!
  • mahimag
    0 mahimag over 2 years ago
    Hi JS532, Can you share what error you are getting?
  • JS532
    0 JS532 over 2 years ago in reply to mahimag
    Hi mahimag,
    I don't get an error. What I get is values very different. When the pbar is present, the values are ~15ps. When the pbar is deleted, the values are ~5ps. The following are shown under the Name column for an example:
    CLKP: die.90:bga.A1 = 0.013ns relative delay within the match group
    pbar.76:bga.A1 = 0.012ns
    pbar.76:die.90 = 0.015ns
    Perhaps there's a way to exclude the pbar from the calculation but I haven't found it. It's located on the Substrate Geometry / Plating_Bar class so I'm not sure why it would be included in the calculation. The only way I have found that works is to delete pbar.
    I would attach some images but the interface isn't allowing me.
  • mahimag
    0 mahimag over 2 years ago in reply to JS532
    Hi @JS532, in SPB 23.1, we have a property "Ignore_Length_Calc". This can be added to clines for this purpose.
